So after updating to 1.2.2.1, I am now CTD'ing every time I attempt to access my secure chest.
It was not doing this on 1.2.2.0, so I was wondering if there was a list of *exactly* what records were changed in 1.2.2.1. While I am playing with a few mods (nothing too major), I haven't had any issues until now.
Also, is there a downgrade procedure so I can go back to 1.2.2.0? I'm at level 63 and about (I think) half way-ish through the story, so I would *really* prefer not to restart and lose everything.
As an addendum: Does anyone know how to get access to the contents of the Secure Chest via the console? I'm likely going to need to do that in order to fix this if I can't downgrade.
welcome to the forum
what mods do you have installed?
best would be deactivating them one after another:/
is the only thing stated in the changelog. (maybe some armor? skeleton? bodymod?)
if that doesn't help, you might want to open a ticket in the Bugtracker
(no need to register)
if the crash is indeed only tied to the patch (regardless of mods)
there might be a rollback soon, so maybe stop playing for a while.
there are console commands for opening containers in general,
but I have absolutely no idea how they work with these chests
would not recommend.
don't know about downgrading, sorry
Changelog 1.2.2.1:
General:
Races and some books will be displayed properly.
The fact that only races and some books were updated and my game started to crash on me was what surprised me the most. As a means of first response I deactivated ALL my mods and tried it again, but the game still crashed.
Still though, here's a list:
- Enderal - 60 fsp Interface (w/ small cursor addon) by MCModdy11
- FPS Limiter by GriefReaper
- Fine Steel Armor Replacer by Medtech
- Enderal Skill Book Value Rebalance by ConnorTheBrony
- Selna set replacer. by Medtech
- Enderal - Handicraft (smithing) Expanded by Ravenscans
- Skyrim Unlimited Rings And Amulets by glock9mm [customized for Enderal by me using TES5Edit]
- Enderal - Myths and Legends Improved (English and German) by cat_woman1989
- EzEs -Artifact Disenchanting- by xEightballx [customized for Enderal by me using TES5Edit]
- Enhanced Soultrap by ubuntufreakdragon [installed using Enderal-compatible settings as defined by the author]
Could you upload a savegame?
found in ..\Documents\My Games\Skyrim\Saves.
We'll need the skse and the ess of a manual (no quick- or auto-) save.
Pack them to a rar or zip archive and attach them to a post here
12.08.2017 20:28rux616 wrote: So after updating to 1.2.2.1, I am now CTD'ing every time I attempt to access my secure chest.
Running completely vanilla skyrim and enderal.
13.08.2017 10:19MarkusParkus wrote: I'm also getting CtD since update every time I loot chests and bodies or open character inventory, my characters wrists are also invisible since update!
I can reproduce your crash, but only with your save only on the english version.
You've cheated quite a lot, which cheats exactly?
I fixed the forearm issue (don't know why it popped up, nothing was changed on the model).
@rux616
Please attach your save.
Edit: And a question to both of you: Are all saves affected or only new ones? What happens when you start a new game?
stuemper, thanks for taking some time to look into this. I'm not sure if your first question was addressed to me, but I'll answer anyway: I was able to run fine on 1.2.2.0, and only started crashing on 1.2.2.1.
I think this is related to a specific item, because I have an older save from when I was level 53 where I can still access the secure chest, and then a few saves later I am unable to. I feel this is reinforced by the fact that the crashing doesn't happen on a new game. I am attaching both the good and bad save, and my most recent one (which is also bad).
- Save 614 - Last convenient good save I have.
- Save 618 - First convenient bad save I have.
- Save 645 - Most recent (bad) save I have.
Saves.zip
(7.9 MiB) Downloaded 182 times
13.08.2017 12:08stuemper wrote:
This is your report, right? Did you encounter the crash with patch 1.2.0.7 or 1.2.2.0 before patching to 1.2.2.1?
The crash and forearm issue is only since 1.2.2.1, I think the forearm issue was caused by the 'order robes' I got through console commands, if I 'unequip all' through console the forearms return, but I still get the crash when I try open inventory or loot.
I have a save from around 6hours of gameplay ago that isn't affected by the crashes. Also starting a new game is bug free.
Sorry for cheating! its my second play and wanted to rush the early game.
I've used no clipping, god mode, additem, unlock, time advance, killall.
@stuemper Are there any details available that describe exactly which records were touched by 1.2.2.1? If there are then I can help and start hunting around for anything that looks suspect and test it.
Barring that, I ask again if there is any way for me to roll back to 1.2.2.0.
No records were touched with 1.1.2.1, it was only a string fix with a new update.esm. I assume that some mods or/and items added via the console probably caused this problem for you like it happened to @MarkusParkus. Have you recently added mods and/or items?
I would suggest to go back to a previous save and replay it. Does the crashes occur again? Between save 614 and 618 you've placed something in the secure chest which causes it to crash.
