Hello everyone! so, I'm usually very reluctant to open threads, but it seems my problem has not been encountered or discussed before.
Very simply put, when playing enderal I cannot save the game. I have the option to do so (it's not greyed out) and the game warns me it's "saving" on the top left of the screen, but whenever I try to load, the files are just not there. I also noticed that if I try to save over a pre-existing file, the game will just delete it.
The issue occurs only while playing enderal, because as I disinstalled it, Skyrim allowed me to save the game without problem
I don't run skyrim with any sort of mods, so I don't think it's a matter of compatibility, and I am sure it's not due to corrupted save files
I already tried reinstalling (both skyrim and Enderal) numerous times without any sort of improvement. I am pretty much at the bottom of the barrel for what concerns my very limited knowledge. Maybe it's a matter of permissions?
Thanks for your help in advance
EDIT: a little more info: I used to play enderal in the past (about 1 year ago) without encountering any save issue. This only happened after I reinstalled it (tried to play it both from the start, without the old save files, and with the old save files, nothing really changed, which is why I'm sure it's not due to corruption). I am using a registered steam version.
EDIT (SECOND ROUND): since we're probably talking about permissions n stuff, I am using windows 10 and have a bitdefender firewall/antivurs. I've already put the .ini files to "not read-only" and all the .exes in the gamefile are set to run as administrator
welcome to the forum
- in ...\Steam\SteamApps\common\Skyrim run the skse_loader.exe as administrator. maybe that solves it already :/
in a thread over at the steam forums are some more suggestions:
- if you use Bitdefender, whitelist Skyrim (or Enderal if that's listed seperately?)
hope that's somewhat helpful
edit for emphasis
edit for emphasis
10.07.2017 14:14urst wrote: welcome to the forum
edit for emphasis![]()
awesome
but why would you feel stupid? one can't know everything
