I tried some ways posted by the mods it doesnt work completly. I get the purple background on the main menu, when speaking to the npcs they dont talk (no audio), and most importantly it doesnt let me start a new game ( the options continue, new and such disappear and nothing happens)
Remove both .ini files from documents\my games\Skyrim\ and start Skyrim afterwards. Everything should be back to normal.
It seems that the dlc voice lines from the dawnguard dlc people say them with audio (it can be heard) but the regular voice lines like Yes? Hm? Did you need something? dont work. Also i have allready uninstalled those files it doesnt work.
The list of the files from the path /documents/mygames/skyrim is
(Folder) Saves
(Folder) SKSE
(txt document) RenderInfo
(config settings) Skyrim
(Config settings) SkyrimPrefs
(Folder) Saves
(Folder) SKSE
Yeah, but could you please upload them, I want to take a look at them.
I dont know how to, thats why i did it this way.
Under your answer here the button "Dateianhänge" (Attachments).
The folders are best in rar or zip format.
Here
SKSE.zip
(103.42 KiB) Downloaded 749 times
Saves.zip
(12.18 MiB) Downloaded 826 times
RendererInfo.zip
(469 Bytes) Downloaded 750 times
And the other two files:
SkyrimPrefs.zip
(1.65 KiB) Downloaded 716 times
Skyrim.zip
(1.05 KiB) Downloaded 759 times
did you delete the skyrim.ini as stuemper suggested?
Skyrim should have created a new one on launch.
it's still the one Enderal uses, much longer and there are other Masterfiles listed.
if deleting it doesn't work, open it and look for this paragraph
type a ; right in front of sResourceArchiveList2, save the document and try starting Skyrim again.
Any clues to what may be happening?
oh i didnt see that the comment went to the next page
i just now saw it. gonna try it but i did delete those files as steumper suggested.
edit: the initial delete of the file didnt work but after putting the semi-colin where it was suggested it worked! Thanks for all the help!
Sincerely,
Matthew
Sincerely,
Matthew
good to know it worked
(you should now be able to delete that line - the semi-colon made it "invisible" for the ini anyway
but strange that deleting the files didn't work :/
Thanks again for all your help!
And indeed it is very strange.
09.07.2017 08:14urst wrote: it's still the one Enderal uses, much longer and lucky ladys charm 777 com is other Masterfiles listed.
