My enderal is crashing at the loading screen when i click new game i dont know what to do
Welcome to the forum!
First question: did you follow the installation instructions correctly?
Also check out this recent post on the support forum.
i got rid of all the mods that I had installed on my skyrim game and the saves and now reinstalling the game without mods to see if it will not crash. Does the skyrim logo coming up mean that there were mods installed?
do i have to remove the esp files of the mods from the skyrim folder or can i keep them in there even though nexus mod manager has them disabled. No mods are active so im reinstalling the game and the update
it should be alright with mods in the Skyrim folder -
to be save I'd suggest you make a copy of that folder and reinstall Skyrim.
(and then Enderal)
you should then be able to replace the clean install with your modded one
(and then Enderal)
but when i load enderal up it does the skyrim logo not the inital loading screen why?
well.
I don't know.
something went wrong with the installation. can't say much more than that.
also, did you take a look at the above linked thread?
if you followed the install - instructions (and reinstalled it by now?) and the issue persists,
then it might be the ini thing.
I don't know.
i reinstalled skyrim and enderal and got it working because it was the ini problem, but when i start the game it comes up with the error about the skse memory fix not being active. How do i stop that from popping up. The game runs fine after that.
