Ok, first of all I'm pretty sure I messed up.
I had 3DNPCs and one other mod in my data folder when I installed Enderal, didn't think anything of it. I should have tested my install of Enderal before I went monkeying around with modding it. But I'm too dumb for that.
So after I finished that bit of indiscretion I started Enderal which went fine up until actually getting into the game. SkyUI didn't work at all. I knew not to install SkyUI because you guys included it, so its not that. There was also an issue with the cutscenes not playing. I figured I could just remove all my mods and try that but it didn't work. Then I figured I should try to uninstall Enderal and then Skyrim and do a clean install of both. That's where I'm at now because I can't uninstall Enderal. I got this error about halfway through uninstalling the first time and now i get it immediately. The first time I clicked continue hoping it would clear itself up but it didn't help so I had to quit.
Clicking details gives me this,
Could I just do an uninstall and clean reinstall of Skyrim to clear this up? I haven't done much on this install and really don't mind if I lose my settings. I apologize if this is tl;dr or if this was a duplicate thread, I looked around and couldn't find anything quite like it.
Update: Weirdly it seems to have cleared itself up, no explanation as to how or why. My apologies. Now I'm just having a problem with starting a game on Skyrim.
Namely, it doesn't, just stays on title screen with music playing I suspect I can fix this with a clean reinstall tho.
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately .
Access to the path 'D:\Steam\steamapps\common\Skyrim\data\Interface\exported\skyui' is denied.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'D:\Steam\steamapps\common\Skyrim\data\Interface\exported\skyui' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.AddSearchableDirsToStack(SearchData localSearchData)
at System.IO.FileSystemEnumerableIterator`1.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
at Launcher_01.formPanSetUp.collectFilesSkyrimDirectory(String backupPath, gameBackup game)
at Launcher_01.formPanSetUp.deleteOrBackup(String path)
at Launcher_01.formPanSetUp.Installswitcher(SByte i)
at Launcher_01.formPanSetUp.btn_InstallationNext_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2053.0 built by: NET47REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Enderal Launcher
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///D:/Steam/steamapps/common/Skyrim/Enderal%20Launcher.exe
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
06.07.2017 16:43Spiranha wrote: Update: Weirdly it seems to have cleared itself up, no explanation as to how or why. My apologies. Now I'm just having a problem with starting a game on Skyrim.Namely, it doesn't, just stays on title screen with music playing I suspect I can fix this with a clean reinstall tho.
