2 posts • Page 1 of 1
Hi guys,
i'll just get straight into it, the problem is that when i launch enderal, i get an error message that says that TESV.exe can't be found (while the executable is in the same folder as the launcher), the game can start up but i get no textures whatsoever, i can move and jump and access the menu but it is like i am moving in a white space, music plays and the beginning quest is given
i have tried running the launcher as an administrator but that doesn't work, i don't know that much about computers but i got the game installed correctly, are there any fixes you guys are aware of?
i can always send an image of the error message,
hope you guys can help
xoxo MushiKing
How did you install Enderal, on a clean install or on a modded one? Do you use NMM or MO? Where did you download the installation package from?
Do you have any mods or ENBs enabled/installed (ENBs should defintely not be in the folder)?
