Hello, I am facing a rather odd issue with Enderal at the moment. For some reason, when I get to the main menu, the cursor is stuck in the middle of the screen and it will not move. The keyboard is also unresponsive, so I am unable to load my game or do anything else. I played a couple of days ago, at which time Enderal and all the controls worked fine. I did just install the update a few hours ago, so I suppose there is a possibility something could have gone wrong with that. Could someone please offer any advice/assistance? It would be greatly appreciated. Thank you.
Enderal Cursor Stuck
Enderal Cursor.jpg (322.94 KiB) Viewed 2694 times
hm.
- reboot your PC, according to this
that could help
- delete the two ini files located in Documents\My Games\Skyrim (game will create new ones on launch)
(just to make sure - you do not have a drawing (/ graphic) tablet with the pen lying on it?)
if this doesn't help you could try loading the updates again
good luck
that could help
good luck
Hello, thank you for helping me again!
Restarting my PC was the first thing I tried, but unfortunately, it did nothing. Also, I can't draw to save my life -so no tablet- and I checked to ensure I did not have a gamepad in.
Could uninstalling Enderal work, rather than just editing the file? I ask because it does not appear that I have the file conf.sur or a folder (?) labeled Enderal Launcher - I only have the Enderal Launcher.exe.
(helping is exactly whatI'm here for
if it's indeed the update that causing the issue, than yeah, reinstalling would work.
strange though that you don't have these folders :/
You definetly have this folder in your Skyrim/Enderal directory, otherwise the launcher would not even start.
Hm, that is odd. Searching for those files in my taskbar, as well as the Skyrim folder itself did nothing.
However, I did manage to fix the issue by uninstalling, then reinstalling the whole shebang (Enderal and Skyrim). Thank you again for all the feedback!
