Hello!
I have an issue regarding experience points. Or at least i think so. As far as i have heard the amount of experience points required to level up is increasing each time you level up. This is NOT the case for me. Every time i level up the same amount of exp points is required to level up again, which is 6000. I am currently level 30 and have 106 000 experience points.
Is it supposed to be this way or am i experiencing an error?
I do really hope there is a solution, since it is really annoying to level up every five minutes of gameplay.
As I already requested in your bug tracker ticket, please attach a savegame over there. Thanks!
It is done. Thanks in advance!
Hello!
Have you found out anything new?
Thank you!
Thank you!
We are looking into it.
Forgive me for being repetetive, but is there any chance this issue can be resolved? I really like the game and I am eager to play again!
Mhmm, the experience points limits increase slowly, but fine, as far as I tested it with your save. The balancing of the levels will change with the DLC (it will be slower overall).
I do not understand the question. There are not only new quests and skills. The DLC also offers a new alternative end. For this you have to start a new game and start at level 1.
Otherwise it makes little sense.
I only want to do the new quests; I don't want to try to obtain the new alternate ending nor try out new skills. Maybe later I will start a new game.
The level rebalancing only applies for new playthroughs. We recommend to start a new one because we can't guarantee one hundred percent savegame compatibility. We try it, but it's really difficult - There are so many things changing stuff, we can't test them for all possibilities.
