20 posts • Page 1 of 2
Indefinite Update
Post by creepcat »
So the update will download but not install. This is my first time installing the mod itself, and updating. Once it gets to the install process, it stays at 0% but the left number continues on indefinitely. 100+/9.
I have tried everything on the wiki page about launcher debugging.
But NOTHING has worked. And the step where it says to replace the sCurrentVersion with an older version, in my file, it's already the older version there. When I go into the update folder, ALL updates are in there. I've tried clearing them, it just downloads them again, but gets stuck on the install process.
Anyone else? Or anyone find a fix for this? This mod looks really awesome, I have yet to actually try it :(
Re: Indefinite Update
Post by stuemper »
Do you run the launcher as admin? Have you tried restarting your PC and tried reconnecting your internet? Do you have the launcher on the whitelist of your fireall / windows defender / anti virus? Which OS is installed?
Please attach your LauncherLog:
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
Post by creepcat »
Yes I've run it as admin, and I've tried restarting my pc. It doesn't appear to be any issues with internet connection.
I haven't tried whitelisting it on my firewall. I dont have an anti virus. And I'm running WIndows 10.
I'm unable to post the launcher log, because it's WAYYY too long. Is there a certain part you wanna see?
Post by creepcat »
I found where they break up. Heres the most recent one i tried today.
[[ Starting Launcher ]]
Log started at 2017/02/06 11:58:19
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A54
Release version: Skyrim Classic
Build date: 2/5/2017 11:55:04 PM
Creation date: 2/5/2017 11:55:05 PM
App start location: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\
App game folder: Skyrim\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.0.0
Internet connection: True
Installation status: True
Steam status: True
OneTweak status: True
Directory search status: True
Master found: False
SKSE found: True
Last external startup path: C:\ *** MASKED USERPATH *** \Downloads\
Last external executable: Enderal Launcher.exe
Backup path Enderal: path
Backup path Skyrim: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<11:58:19> Conf - Initialize conf file
<11:58:19> Conf - Initialize conf file [DONE]
<11:58:19> Conf - Save conf file
<11:58:19> Conf - Save conf file [DONE]
<11:58:19> Conf - Checking Environment
<11:58:19> Conf - Checking Environment [DONE]
<11:58:19> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalLauncher\system\ recursive
<11:58:19> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalLauncher\update\ recursive
<11:58:19> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalLauncher\backup\ top level
<11:58:19> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\ top level
<11:58:19> Main - Initialize Unpatcher
<11:58:19> Unpa - Start cleanup
<11:58:19> Main - Unpatcher [DONE]
<11:58:19> Main - Create environment
<11:58:19> Main - Create environment [DONE]
<11:58:19> Main - Initialize network
<11:58:19> Net - Connection enabled in settings
<11:58:19> Net - System is connected to network
<11:58:19> Net - Try to establish server connection thread
<11:58:19> Net - Thread STARTED
<11:58:19> Main - Initialize network [DONE]
<11:58:19> Net - Choose server
<11:58:19> Main - Initialize intervall [DONE]
<11:58:19> Net - Connect to [DL1]
<11:58:19> Main - Initialize PanBase [DONE]
<11:58:19> Main - Initialize CPanel
<11:58:19> Cp - Cp Initialisation
<11:58:19> Main - Initialize CPanel [DONE]
<11:58:19> Cp - No connection to server established yet, try again in 5 seconds...
<11:58:19> Net - Connection default port: True
<11:58:19> Cp - Check Cp file
<11:58:19> Conf - Hardware Scan:
<11:58:19> Conf - CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, Speed: 3101, Cores: 4
<11:58:19> Cp - Abort: Check existing Pics
<11:58:19> Conf - RAM: 11 GB
<11:58:19> Cp - Start Cp pic checker
<11:58:19> Conf - DISC: 57797 MB
<11:58:19> Cp - All pics found
<11:58:21> Net - Connection OK
<11:58:21> Net - Start listing available versions on [DL1]
<11:58:21> Net - 1.1.2.0 F 1
<11:58:21> Net - 1.1.2.3 M 1
<11:58:21> Net - 1.1.2.5 S 1
<11:58:21> Net - 1.1.2.6 M 1
<11:58:21> Net - 1.1.2.7 S 1
<11:58:21> Net - 1.1.2.9 L 1
<11:58:21> Net - 1.1.3.0 F 1
<11:58:21> Net - 1.1.3.1 L 1
<11:58:21> Net - 1.1.3.3 M 1
<11:58:21> Net - 1.1.3.4 S 1
<11:58:21> Net - 1.1.3.5 M 1
<11:58:21> Net - 1.1.5.0 S 1
<11:58:21> Net - 1.1.5.1 M 1
<11:58:21> Net - 1.1.5.2 L 1
<11:58:21> Net - 1.1.5.3 M 1
<11:58:21> Net - 1.1.5.4 S 1
<11:58:21> Net - 1.1.5.5 M 1
<11:58:21> Net - 1.1.5.6 L 1
<11:58:21> Net - 1.1.5.7 L 1
<11:58:21> Net - 1.1.5.9 S 1
<11:58:21> Net - 1.1.6.0 M 1
<11:58:21> Net - 1.1.6.1 L 1
<11:58:21> Net - 1.1.6.3 S 1
<11:58:21> Net - 1.1.6.4 M 1
<11:58:21> Net - 1.1.6.5 L 1
<11:58:21> Net - 1.1.6.8 S 1
<11:58:21> Net - 1.1.6.9 M 1
<11:58:21> Net - 1.1.7.0 L 1
<11:58:21> Net - 1.1.7.1 L 1
<11:58:21> Net - 1.1.7.2 M 1
<11:58:21> Net - 1.1.7.3 L 1
<11:58:21> Net - Needed update packages: 9
<11:58:21> Net - [1.1.3.0][F]
<11:58:21> Net - [1.1.3.4]
<11:58:21> Net - [1.1.5.0]
<11:58:21> Net - [1.1.5.4]
<11:58:21> Net - [1.1.5.9]
<11:58:21> Net - [1.1.6.3]
<11:58:21> Net - [1.1.6.8]
<11:58:21> Net - [1.1.7.2][M]
<11:58:21> Net - [1.1.7.3][L]
<11:58:22> Update - Installing update authorised:
<11:58:22> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalLauncher\update\ recursive
<11:58:22> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\ top level
<11:58:22> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\data\ top level
<11:58:22> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:22> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\Data/ top level
<11:58:22> Update - Started, extracting file: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:22> Update - Files to extract: 417 At rate: 0.2398082
<11:58:22> Update - Temporary file found and delete it: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\Data/EEN - SoundExtra.bsa.tmp
<11:58:23> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\ top level
<11:58:23> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\data\ top level
<11:58:23> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:23> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\Data/ top level
<11:58:23> Update - Started, extracting file: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:23> Update - Files to extract: 417 At rate: 0.2398082
<11:58:24> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\data\ top level
<11:58:24> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:24> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\Data/ top level
<11:58:24> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\ top level
<11:58:24> Update - Started, extracting file: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:24> Update - Files to extract: 417 At rate: 0.2398082
<11:58:24> Cp - Retry thread started attempt #1
<11:58:24> Cp - Try to compare server with local file
<11:58:24> Cp - Connection port: 80
<11:58:24> Cp - Connection default port: True
<11:58:24> Cp - Connection proxy bypassed: True
<11:58:24> Cp - Connection OK
<11:58:24> Cp - 12/2/2016 4:38:16 AM 2/5/2017 11:55:19 PM
<11:58:24> Cp - Up-to-date
<11:58:24> Cp - Check Cp file
<11:58:24> Cp - Read old Cp file
<11:58:24> Cp - Abort: Check existing Pics
<11:58:24> Cp - Start Cp pic checker
<11:58:24> Cp - All pics found
<11:58:25> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\ top level
<11:58:25> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\data\ top level
<11:58:25> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:25> Func - RWP: C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\Data/ top level
<11:58:25> Update - Started, extracting file: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<11:58:25> Update - Files to extract: 417 At rate: 0.2398082
<11:58:25> Conf - Save conf file
<11:58:25> Conf - Save conf file [DONE]
<11:58:25> Exit(A)
Post by stuemper »
There is a button to attach files under the entry field when you post a reply. Please attach the whole log. :)
Post by creepcat »
Oh, my bad, here we go.
Launcher.log
(192.05 KiB) Downloaded 53 times
Post by stuemper »
mhmm, somehow you are downloading broken updates...
We have to check what could go wrong, and this could take some time :/
Post by creepcat »
Well, I appreciate the replies. :) Please keep me updated.
Post by stuemper »
Yeah, we try our best.
Have you tried a complete reinstall of Enderal and Skyrim or redownloading a new launcher (and copying it over the old one)?
Post by creepcat »
I tried the launcher, yeah. But I haven't tried reinstalling skyrim. So let me try that.
