I have great problems trying to enter the memory of the deat Pyrean after using the "The Word Of The Dead".
I seen the loading screens with the still pictures with text under. Then when I am supposed to enter the memory of the Pyrean and play as him the game does a CTD.
I've tried changing the game to using only one core on the CPU and running at 1920*1080, both windowed and non-windowed mode to no avail.
I cound not remember the name "The Word Of The Dead" so I loaded the game while having the browser running in the background and for some reason the game loaded the Pyrean's memory correctly after which I made a hard save (also have a hard save right before clicking "The Word Of The Dead" in case you are interested). Had to close game as it dislikes alt-tabbing so I hope my save works.
Game setting is: 16:9 aspect ratio, 2560*1440, VSync and WIndow mode are both OFF (have tried with WIndow mode On, made no difference).
Game runs smoothly but with the occational Skyrim crash especially after playing for some hours straight (memory leak? - Enderal settings says 7GB use)
My system:
Win10 Pro 64-bit
Asus X79-Deluxe
i7 3930K
4x4GB RAM @ 1866Mhz
Geforce 980Ti Hybrid, driver version 376.33 @ 2560*1440, 60 hz, G-sync is enabled.
Game running from SSD
Everything at stock speeds.
My system:
Win10 Pro 64-bit
Asus X79-Deluxe
i7 3930K
4x4GB RAM @ 1866Mhz
Sorry for the spelling in my first post.
Yes, I got it working, no idea how but guess it might have something to do with starting the game while having the browser (IE11) minimized.
I had one problem while playing as the Pyrean. The game froze and forced me to a hard reboot of my computer. It happened right after my brother(?) got killed. Luckily I had made a quick save right before, it went without problems from there.
Edit: Just a thought. Right after making the dead Pyrean arrive at the place I automatically draw my sword for some reason. I've tried sheating the sword, or changing to my bow without that made a difference on the crash but, maybe the automatic unnessesary drawing of the sword might have something to do with it? It could also be because the game has to change the player into the ghost form without actually removing any of the clothing, weapons etc. All of that has to be re-calculated while at the same time the game is loading a new level.
I'm not a programmer, just a thought. Maybe if the level could load and then the arrival of the ghostly Pyrean is delayed a few seconds. Have some scared animal run away so something happens while people are waiting on being able to play?
