Hello, I encoundered a bug in the game and I can't continue the story!
More specifically, I can't find the Dal Guess black stone! I finished the quest (the kid transformed and I killed it, then the dream world is destroyed), but I can't interact with him when he is dead (I press "E" when he is lying on his bed but nothing happens), and I am stuck! I also can't find the ID of that black stone to add it to my inventory to (possibly?) end the quest!
I zipped my last save (.SKSE and .ESS, quicksave)
Thanks!!
Thanks!!
Saves.zip
(2.8 MiB) Downloaded 78 times
That's not a bug. You got it as soon as you burried Rynéus!
You can go back the temple and talk with arch magister
Thanks for the answer, I tried talking to the arch magister but there was not any option regarding the quest! Also... there was no burial? The kid is just lying dead on his house!
Thanks
Thanks
That is odd. I just loaded in your savegame, and it was fine. And your questlog said that you burried him.
Could you upload a hardsave, I will install the english version again later this evening/night to test this out. It could be a so called "Scrollbug" in which dialogue topics bug out.
ok I talked to him again (from desperation) and there was an option for the quest! Finally, I gave him the Stone (although it wasn't in my inventory), anyway thanks!
Well I have another problem....I talked to him and gave him 2/3 stones.... now I can't give him the 3rd stone! (There is no option when talking to him, I have the stone on my inventory but strangely I can drop it and then get it again) Can you tell me a console code to bypass this to end this quest? Sorry for annoying you
Thanks!
Thanks!
Oh, yeah it's a "scrollbug" give me your savegame. I'll fix it for you.
Enter the following codes in the console:
I will test out the scrollbug later this night with the english version.
Code Select all
setstage mq12a 17
setstage mq12a 20It worked, thank you very much! You saved me! I hope my bug will help you and your team fix it for others later, anyway thanks again now I gotta save Enderal from Coarek
Even with the english version: There is no bugged out topic. Everything is in place :/
What do you mean? Anyway, later I encountered another bug at the end of Black Light Part II where Tealor talks with the Archmagister about the beacon problem and tells me to rest, that's where the bug happened but I simply setstaged (trying values!) and fixed it, it was another scrollbug
dimkar wrote:What do you mean? Anyway, later I encountered another bug at the end of Black Light Part II where Tealor talks with the Archmagister about the beacon problem and tells me to rest, that's where the bug happened but I simply setstaged (trying values!) and fixed it, it was another scrollbug
Do you have the latest version 1.1.5.3 installed?
I have zero mods! I never installed any mods, only SkyUI but that was pre-installed with Enderal! And yes I use the latest version, everything works fine now though, thanks!
Installing SkyUI could break the interface in many ways. i would recommend to uninstall it!
Check in the Enderal Launcher in the "Data files" tab if anything else is interfering.
It was pre-installed with Enderal though! Anyway that was the only problem I encountered, (crashes are normal and I don't care! We get a great FREE mod, no complaints!)
Thanks
Thanks
Ah, I thought that you manually installed SkyUI again. These dialogue bugs are strange.
It doesn't matter really, as long as I can setstage! But what I don't understand is that it worked for you, and not for me but nevermind!
