hello. almost every time when I try to exit game it gives me "Skyrim stopped responding" message. what could possible cause this?
I have UseOSAllocators=1 line in CrashFix plugin, and I also tried different settings (OneTweak on and off, windowed mode, etc) but game still crashed.
could it be RaceMenu mod, since it's the only mod I use that may cause something like that?
I would very appereciate help.
I attached Launcher log
edit. there is "Game has crashed with exception address 0xF5249F!" line in CrashFixPluginLog
Launcher.log
(113.53 KiB) Downloaded 216 times
Does the crashes occur without the usage of mods?
Could you attach the CrashFixPluginLog?
You could try to install and execute the following programs:
- C:\program files(x86)\Steam\steamapps\common\Skyrim\DirectX10\DXSETUP
- C:\program files(x86)\Steam\steamapps\common\Skyrim\DotNetFX\dotnetfx35setup
- C:\program files(x86)\Steam\steamapps\common\Skyrim\VCRedist\vcredist_x86
All necessary programs are already installed. I have two skyrim setups - one heavy modded for regular gaming and another without any mods for Enderal only.
I removed all my mods (I used only compatible ones from that list: https://docs.google.com/spreadsheets/d/ ... edit#gid=0 ), but game is still crashing...
The only way is to set UseOSAllocators=0 in Crashfix plugin.
I attached log:
edit: CrashFixPluginLog.txt only contains this line: "12 Nov 21:22:19 Game has crashed with exception address 0xF5249F!"
I attached log:
crash_2016_11_12_21-22-19.txt
(1.51 KiB) Downloaded 221 times
Well, we can't do anything to let this bug do not occur.
The "compatible mod list for Enderal" is pretty useless since we have not checked them. The most mods are tested poorly: "I've played 3 hours with mod xyz -> it must be compatible!".
UseOSAllocators=1 increases the system requirements for Enderal, so it could be just an issue between the crashfixplugin and your hardware.
If it works with UseOSAllocators=0, then stick with this setting.
I think I found the solution (at least for me): to install Enb, it isn't necessary to activate any effects, the most important is to set MEMORY block in enblocal.ini correctly with UseOSAllocators=1 in CrashFix:
ExpandSystemMemoryX64=false
ReduceSystemMemoryUsage=true
And no more crashes.
edit. Setting RecordCrashInfo=0 in CrashFix also helped (no enb needed)
