3 posts • Page 1 of 1
Hello everyone!
Recently, I had been wanting to play Enderal again as I've grown less busy now but I've now remembered that my game has refused to work ever since I had installed 1.1.3.5 from the Launcher.
The game launches fine but the only problem is when it comes to loading up the options to, for example, select a "New Game" or (what I'd like to do) "Load Game"/"Continue". None of the text shows up actually and no audio is playing. I'll just be staring at the wonderful art of the main screen. I remembered I've left the game open for a good 5-10 minutes before and I've gained no progress from then. The only way I can close out of the game is forcing it closed through the Task Manager.
I don't have any other mods installed except for Enderal. Also, since I have a program installed on my computer that keeps track of my frame rate In-game I only seem to be getting about 19-30FPS as the game sits idle which normally is only when I'm actually playing the game and I usually get around 60FPS when in a menu or on the main menu.
I'm currently running Enderal on my Windows 10 computer and it worked fine before and never had an issue. The Launcher says my game is up-to-date so I assume the problem cannot stem from there.
Any help would be greatly appreaciated as I'd like to get back to playing Enderal soon to see where I last stopped and perhaps continue it! Sorry if some of it sounded weird. I'm not the best at explaining situtations majority of the time.
~MorbidDreams
Edit: I've fixed the problem and now my game runs well and works. Feel free to delete/lock it.
Re: Stuck on Main Menu
Post by stuemper »
I would recommend a reinstall of Enderal. Uninstall Enderal completely via the Enderal Launcher (do not archive it). Skyrim will be restored. Head to the Steam library and verify Skyrim's game cache and let it download the missing files.
Redownload the newest english Launcher from http://enderal.com and copy it over to your Skyrim directory. Start the installation from scratch with a new installation package. Do not interupt the process, after that hit the update button.
Your Savegames will remain untouched.
Does it work
Additionally you could attach your old launcherlog:
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
Does it work
I've followed your instructions and uninstalled Enderal completely through the launcher, verified my game files but as I look through my Skyrim folder it appears I still have a folder for the "EnderalLauncher" with 3 other subfolders in it. Should I go delete the "EnderalLauncher" folder completely and then let the Launcher install to the spot it wishes?
Currently the Launcher wants to install it to:
C:\Program Files (x86)\Steam\SteamApps\common\Skyrim\EnderalInstall_EN.gz
But, it won't let me click "Next" even when I have the "Enderal Installation File" selected.
