12 posts • Page 1 of 1
I just finished The Word of the Dead and Fragments of the Past, in that order, and the next story quest will not trigger. I have another character that is way farther in the story line than this character is and i did not encounter that problem.. could someone possibly provide me the console commands to trigger the next quest in the sequence? Because none of the NPCs have anything interesting to say, so I'm assuming console commands are my only option.
Thanks in advance.
Let me take a look on hit. Please attach your savegame.
Thanks.
I tried uploading it, but the forum stops me from submitting the reply and claims that "The extension is not allowed" when I attach my compressed file.
What? Which compression did you choose?
Added a random save for testing
housingbug.rar
(2.75 MiB) Downloaded 238 times
I compressed using 7zip. Should I try using a different program?
No, you should be fine using any compressing program.
Could you upload them to a filehoster and link them to me?
Could you uplaod them to a filehoster and link them to me?
https://mega.nz/#F!2Z4jzJza!p_dVfn16RMUWFZxBZ4dRmA
here's the download link to the file containing the .skse and the .ess
Is this thread dead..? Because I still need help with this issue if you can help.
I'm behind proxy / vpn and mega.nz is blocked.
Use WinRAR, 7-Zip, WinZip to zip both files together and attach the archive.
Okay it worked this time, no post error.
GlitterGroin's save file.zip
(2.14 MiB) Downloaded 247 times
No, the thread is not dead, we try to answer to every request. It happens that we have busy weeks and that we have little to no time for Enderal.
Do you have a savegame which can be loaded during the last conversation? Would be good to check where the problem is comming from.
Thanks in advance.
Was reluctant because where you were at also involves a character quest.
Tilliboy or someone with SureAI better qualified to identify problem than the likes of me... ; )
Your save is a puzzle though.
Unless mistaken, the game thinks you have finished both parts of 'Fragments of the Past! : 0 !
If you have an earlier save I'd replay from earlier in the game for story, and avoid missing any Calia related chats.
If want to console though, cross fingers? ; )
1.) Copy or backup save game & autosaves. Name one "Temp_MQ07Fix" (or whatever you can remember.) This just protects your saves in case console messes them up.
Before console, head to Market Place, or Noble District in Ark. An NPC from 'Deus Ex Machina' wants to thank you, but forget where I met him.
setstage MQ7bAftermath 10
setstage MQ7bAftermath 15
; close console. A man you rescued in Starling ruins should appear and thank you. Save as diff game?
;console again
setstage MQ7bAftermath 20
;In save, I tested it outside at Sun Temple so maybe a good idea to go there before continue.
setstage MQ08Prologue 5
;hopefully you should see a "wait" objective, and "Interlude" should be your story quest.
Best wishes & have fun with it!
