When I get into the game i can't move or anything, the only thing i can do is look around and the quest starts but i cant move or open my inventory. I've seen other people have this bug but they say reinstalling it works but i have reinstalled it 4 times now and the same thing happens everytime.
- Do you have a XBOX Controller or equivalent? Disable / Unplug your Controller.
- Remove any mods / or mod configuration files
Start with a new 'Clean Install'.
Backup your Skyrim Saves and Skyrim Folder.
\\steamapps\common\Skyrim\ [Skyrim Install Directory]
\\Documents\My Games\Skyrim\ [Configuration, Saves]
1. Open STEAM. In STEAM goto 'The Elder Scrolls V: Skyrim'
Right click and select 'Delete local content'
2. Goto your Workspace and search your Skyrim Instalaltion Directory.
Remove the 'Skyrim' folder manually. Example: '\\steamapps\common\Skyrim\ [Skyrim Install Directory]'
3. Goto '\\Documents\My Games\Skyrim\' [Configuration, Saves] and remove it manually. Your save files are stored here. Create a backup before you delete anything.
4. Now Install SKYRIM in STEAM.
5. Start Skyrim once and exist (so it autodetects settings) / Start Skyrim and test your default game.
6. Install Enderal. (http://en.wiki.sureai.net/Enderal:Techn ... stallation)
7. Update Enderal with Enderal Launcher.
