The artifact is the place where you can not get it. Could someone give the code ID for artifact?
Use the console command
to get it.
It must have slipped through the ground during the fight.
Code Select all
tclIt must have slipped through the ground during the fight.
Now is problem with Old Miskahmur.
I can clearly see that you have some mods active. They could be the cause, upload a savegame. I'll look into your problem. Moved to support.
Thanks.
Thanks.
The marker should be on the cloosed door.
Just pull down the 3 levers in this level to unlock the door.
At the end it should point towards the exit.
I submita ticket at the bugtracker.
This will be fixed in the hotfix to patch 1.2.5.0.
