5 posts • Page 1 of 1
Hello
I installed the mod when the English version was released and played for some hours since then. The launcher worked fine and installed updates that were released. Today I started the launcher and all the buttons are greyed out, except the "Install Enderal" button which wants to download and install the mod again. I haven't touched the game folder, workshop or mods while I was playing Enderal.
If I launch Skyrim through the SKSE launcher I see the Enderal main menu and all the mod files are in the Data folder. How to fix the launcher so that it detects the mod is installed without redownloading everything?
Upload your launcherlog:
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
I am having the same problem.. I don't want to install it all over again. I have played 55 hours in this game but it suddenly happened. The Launcher wants me to install it again.
Launcher.log
(246.46 KiB) Downloaded 92 times
Close the Enderal Launcher.
Find the file conf.sur in \\SteamApps\common\Skyrim\EnderalLauncher\system\config and open the file with notepad (Open with... > select Notepad).
bInstallStat=1
sLastExternalStartUpPath=C:\PathToSteamLibrary\SteamApps\common\Skyrim\
sSkyrimFolderPath=C:\PathToSteamLibrary\SteamApps\common\Skyrim\
sCurrentVersion=1.1.0.0
bInstallStat > set to 1
sSkyrimFolderPath= Path to your Skyrim(Enderal) installation folder (not the Data folder)
sCurrentVersion > set to 1.1.0.0
Save file.
Update Enderal to the latest version.
Check configuration settings.
Everything working again?
Hey man! Thanks! It's fixed! :thumbsup:
