6 posts • Page 1 of 1
Whenever I try to enter the Ark - Gatehouse after Tealor, my Skyrim stops responding and crashes to the desktop.
Any help would be appreciated as I really love this mod and this bug is making my story unplayable :(
Upload your savegame. I'll see what I can do.
A savegame consists of two files: one .skse and one .ess (please zip them)
Thanks.
I have the exact same crash issue. Enderal has been working great up until now. Will there be a patch? My version is a little modded but not near as much as my Skyrim version was. Great game! I've finished a lot of side quests and have been at many locations. Look forward to a sequel.
I am experiencing the same issue. I am enjoying it a whole lot but I am not able to continue at all, it just crashes when I try to enter the gatehouse during black light part 2.
Is there a fix?
Attached is a zip file containing the two savegame files.
Thank you in advance.
NFLedEnderalCrash.zip
(2.04 MiB) Downloaded 142 times
Hmmm... Lucky didn't happen to me, but if a number of people... A pattern?
Ran through your save & CTD every time. COC "MQ12bWallInterior" = CTD too. : (
Until Tilliboy & dev's can patch, hopefully console can help get you past this point if want to try it.
If so...
1.) Make a copy or backup autosaves & savegames.
2.) Make a temporary file like "Temp_MQ12bError" or whatever you can remember. This just protects your 'real' saves if console doesn't work.
2.) Console the following & cross fingers. : )
GetStage MQ12b
; 'kyle' is at stage 55 so I'm starting from there
SetStage MQ12b 60
;objective should say repair crank
SetStage MQ12b 65
SetStage MQ12b 70
SetStage MQ12b 75
;Save another test game and prepare for combat - assassin is tough
SetStage MQ12b 80
;Assassin! Kill him or if he is too tough, console past (in the real game I think others helped but not sure)
SetStage MQ12b 85
SetStage MQ12b 90
SetStage MQ12b 100
;completes repair crank objective & tells you to help save guards outside (you can't - it's scripted that way)
Setstage MQ12b 105
;Tealor & Yuslan meet up @ city gate. Approach it and should force dialogue with Taranor Coarack on other side of invisible barrier. (in actual game it has a magic effect but not in console I just tested) Dialogue with Taranor makes little difference unless want to learn what motivates him.
;things should go according to script now, but if not...
SetStage MQ12b 115
;you are given a teleport scroll back to the Sun Temple.
;Teleport back & Tealor will be busy with something else. When he's done, follow him to where Lexil awaits with news about the beacon.
;That should hopefully start "Black Light, Part III" for you and can get on with game.
Whatever you decide, best wishes!
That worked, thank you!
I loaded the latest save, typed tilde ~, typed several of the commands you gave, it crashed again at the same point but then I loaded it again and typed a few more commands up to I think 80 (or maybe 100) and it worked.
