SOLVED : YOU NEED STEAM RUNNING FOR THE INSTALLER TO WORK!
I cant start it at all, it just crashes .
I cannot install the game.
I tried allowing it to run trough firewall, i checked to see if i have the verdana font and tried to run it as administrator and in different compatability modes, but nothing
i get the this message:
Ok, which Windows version are you using? And is it 32 or 64 bit? Is .NET Framework installed and which version of it?
Hoxyd wrote:Ok, which Windows version are you using? And is it 32 or 64 bit? Is .NET Framework installed and which version of it?
Unfortunately the error message tells nothing useful about the error. So I do not know what causes this problem.
TheKharjo wrote:I cant start it at all, it just crashes .
Tilliboy wrote:Your Steam should be running in the background!TheKharjo wrote:I cant start it at all, it just crashes .
EDIT: yap it works now... you should put this info on the download page,
