2 posts • Page 1 of 1
First of all, really really enjoying the game! Thank you for doing such an awesome job!
My only two problems so far are the following
1) Hero Menu. When played in full screen mode, the Hero menu appears larger then the screen and cuts off portions of both sides. This also happens when "fast travel" options appear.
2) When the loading screen pops up, the bottom half is covered by the mist from Skyrim's loading screen. Not sure this is normal or not, I have not seen it on youtube play throughs.
Any help would be awesome!
We only support 16:9 ratios/resolutions.
If you play on higher resolutions then 1920x1080 we can recommend using the tool FlawlessWidescreen.
Lower resolutions are not supported right now.
