3 posts • Page 1 of 1
I've downloaded and installed Enderal. Fresh and smooth and all
After I downloaded it, it told me to update to patch 1.2.9 (I think), and while installing after it goes to 100% it just keep patching to hundreds of thousands/5 (It literally goes to 100K++)
Well I quit the launcher, and then I reopened it. It said that the update was installed sucessfully. But now when I tried to launch Enderal it said that "Enderal needs an update first."
Does anyone know how to fix this? I'm pretty confused right now
Re: Enderal Needs an Update?
Post by Wodan »
Hey, just ran into the same issue.
I noticed at the start of the update was the label 1/5. After closing the launcher and then trying to update again I noticed it downloaded again, and was now labelled 2/5.
So each time I let the updater reach 100% downloaded, and then close and reopen until 5/5.
Upon opening the launcher the next time the message changed to update ready to install. Sure enough...update successful.
Very odd and hopefully unintentional update process but hey it works lol.
This usually happens if either your internet connection was unstalbe during the download, your lancher is blocked by security programs or the random kind of bug which tends to happen at the worst possible moments ^^
http://en.wiki.sureai.net/Enderal:LauncherDebugging
On this site you should find a solution to your problem, if it does not work come back and report again :-)
