Yep, I have both possible passwords, but when i click on the seal to try to enter a password, nothing shows up but a mouse comes up and my cursor zooms in and out. but other than that, nothing, i can access the console but thats all i can do. I tried pretty much of everything I can think of. Need help, really want to continue playing this amazing Game/Mod.
Bump, still need help
Been waiting for ever to get a fix for this, had someone on reddit give me the exact console fix for this. Not to bash on the DEVs or anything, but here's the fix. Once you get to the seals, dont click on them, and type this in your console "player.setstage mq11a 125"
Go to the door, open and wala.
Sapro wrote:Been waiting for ever to get a fix for this, had someone on reddit give me the exact console fix for this. Not to bash on the DEVs or anything, but here's the fix. Once you get to the seals, dont click on them, and type this in your console "player.setstage mq11a 125"
So here I am wasting my freetime on guys like you who are bashing around and "waiting for ever to get a fix".
A setstage command is NOT a fix. You can probably get past the problem, but it does not fix anything for all the other players which do not read the forums/reddit etc.
Upload your savegame here. I'll look into your problem.
A savegame consists of two files: one .skse and one .ess (please zip them)
Thanks.
Stuck with the same problem. Didn't make save befor this mission
Here/s my actual save, please help.
Saves.zip
(3.35 MiB) Downloaded 77 times
Did you try to reinstall? You should use a new installation package.
I assume the installation package you used to install Enderal is damaged somehow.
These boxes are there when I'm loading your save.
Do you use any Mods/ENBs?
Also you shouln't use Magelight in that Castle. It causes crashes. Luckily only there.
If a reinstall does not help try out the setstage command which has been posted by the User sapro.
