4 posts • Page 1 of 1
When I launch the game the opening menu appears quickly as usual but when I click "New Game" and confirm "Explore Enderal" the text disappears and the game hangs on that image indefinitely, never starting the new game.
PC Specs:
OS: Windows 10
Processor Intel(R) Core i7-6700K CPU # 4.00GHz 4.00GHz
RAM: 16.00 GB
System type 65-bit Operating System, x64-based processor
Graphics Card: Radeon rx480 8GB
Log:
[[ Starting Launcher ]]
Log started at 2016/08/25 18:57:50
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A48
Release version: Skyrim Classic
Build date: 8/25/2016 11:23:19 AM
Creation date: 8/25/2016 11:10:33 AM
App start location: D:\SteamLibrary\steamapps\common\Skyrim\
App game folder: Skyrim\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.2.6
Internet connection: True
Installation status: True
Steam status: True
OneTweak status: False
Directory search status: True
Last external startup path: C:\ *** MASKED USERPATH *** \Downloads\
Last external executable: Enderal Launcher.exe
Backup path Enderal: path
Backup path Skyrim: D:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<18:57:50> Conf - Initialize conf file
<18:57:50> Conf - Initialize conf file [DONE]
<18:57:50> Conf - Save conf file
<18:57:50> Conf - Save conf file [DONE]
<18:57:50> Conf - Initialize Version
<18:57:50> Conf - Checking Environment
<18:57:50> Conf - Checking Environment [DONE]
<18:57:50> Func - RWP: D:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<18:57:50> Func - RWP: D:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<18:57:50> Func - RWP: D:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<18:57:50> Func - RWP: D:\SteamLibrary\steamapps\common\Skyrim\ top level
<18:57:50> Main - Initialize Unpatcher
<18:57:50> Unpa - Start cleanup
<18:57:50> Main - Unpatcher [DONE]
<18:57:50> Main - Create environment
<18:57:50> Main - Create environment [DONE]
<18:57:50> Main - Initialize network
<18:57:50> Net - Connection enabled in settings
<18:57:50> Net - System is connected to network
<18:57:50> Net - Try to establish server connection thread
<18:57:50> Net - Thread STARTED
<18:57:50> Main - Initialize network [DONE]
<18:57:50> Main - Initialize intervall
<18:57:50> Main - Initialize intervall [DONE]
<18:57:50> Main - Initialize PanBase
<18:57:50> Main - Initialize PanBase [DONE]
<18:57:50> Main - Initialize CPanel
<18:57:50> Cp - Cp Initialisation
<18:57:50> Main - Initialize CPanel [DONE]
<18:57:50> Cp - Abort: Check existing Pics
<18:57:50> Cp - Start Cp pic checker
<18:57:50> Cp - All pics found
<18:57:50> Conf - Hardware Scan:
<18:57:50> Conf - CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, Speed: 4001, Cores: 8
<18:57:50> Conf - GPU: Radeon (TM) RX 480 Graphics, Memory: 4 GB
<18:57:50> Conf - RAM: 15 GB
<18:57:50> Conf - DISC: 3717922 MB
<18:57:51> Net - Connection OK
<18:57:51> Net - Start listing available versions on [DL3]
<18:57:51> Net - 1.1.0.1 M 1
<18:57:51> Net - 1.1.0.9 B 1
<18:57:51> Net - 1.1.1.0 L 1
<18:57:51> Net - 1.1.1.1 L 1
<18:57:51> Net - 1.1.2.0 F 1
<18:57:51> Net - 1.1.2.3 M 1
<18:57:51> Net - 1.1.2.4 L 1
<18:57:51> Net - 1.1.2.5 S 1
<18:57:51> Net - 1.1.2.6 M 1
<18:57:55> Cp - Retry thread started attempt #1
<18:57:55> Cp - Try to compare server with local file
<18:57:55> Cp - Connection port: 80
<18:57:55> Cp - Connection default port: True
<18:57:55> Cp - Connection proxy bypassed: True
<18:57:56> Cp - Connection OK
<18:57:56> Cp - 8/21/2016 7:27:00 AM 8/25/2016 2:23:13 PM
<18:57:56> Cp - Up-to-date
<18:57:56> Cp - Check Cp file
<18:57:56> Cp - Read old Cp file
<18:57:56> Cp - Abort: Check existing Pics
<18:57:56> Cp - Start Cp pic checker
<18:57:56> Cp - All pics found
I had the same issue as you, I uninstalled Skyrim and SKSE on steam completly, re-downloaded Skyrim, installed SKSE and Enderal, and it worked, for some time (game crash on another loading screen, after ~20mn of game).
EDIT : a Moderator told me in my post that SKSE is already provided in Enderal, and that you souldn't reinstall SKSE on steam.
Tried fresh install. Didn't work. Still stalling.
So I figured it out for anybody experiencing this issue.
Turns out the problem was caused by a corrupted download of EnderalEN.gz. To fix this problem, uninstall, redownload and try to install again.
I first noticed suspected this was it when the script extender that came with the file wouldn't launch after I deleted the steam install of SKSE (because it apparently comes with Enderal). After that I noticed that when installing Enderal, it would only unpack Meshses.bsa and then complete. This led me to suspect it was either a problem with the base game or with the unpacker that comes with the launcher, as clearly the unpacker wasn't completing or is getting an exception and the launcher is taking that to mean it completes (As a note to the mod team: You might want to check that your launcher is handling exceptions properly. It should not be saying it completed install if the unpacker experiences a problem). From there, I simply figured that the unpacker wasn't working right because of a corrupted download, so I re-downloaded.
If you yourself are experiencing this issue, I recommend downloading via torrent. It's less likely to give you a problem like this.
Hope this helps someone with the same problem.
