6 posts • Page 1 of 1
I have a problem: whenver I open the map I can see the HUD but there is no map, just fog and if i want to exit I need to restart.
I play on 1280x1024, I have also tried 1280x720, 1280x800 but then the game crashes on the loading screen. I have been playing without the map for a couple hours but its annoying that I can't use it. I haven't seen anyone report of this porblem so I think it could be something with my skyrim? I have reinstalled skyrim and reinstalled Enderal but it didn't help and i don't know what else to do.
Just created ERB-1036:
Bringing up the map screen in Old Hatolis Rock Pass, will show an empty centre frame and will completely freeze the game as no button works, forcing me to take down the game from the task manager process.
Thanks for a great game!
Thanks for the report but please do not post Bugs twice (in the tracker and the support forum). We are loosing the overview if everyone does that.
This issue is known for a long time (Could happen in every extra worldspace).
Does it occur in a certain area ("Old Hatolis" is known for a map freeze) or does it freeze everywhere?
i exit south side of Old Hatolis
(where there are many Nehrimese and spiders)
if i open my map game freezes.
have tried this a few times... confirmed.. every time.
note that all other menu work fine.
appears i am not supposed to be in that area... yet.
my quest tracker is gone on the compass.
if this IS the case, area is quest related...
need to prevent that lower level door from opening
until on the appropriate quest.
I don't know if this is a possible bug, or was done on purpose, or is just my computer.
The Old Hatolis area is broken down into a number of different sub-areas, which are separated either by doors or portals.
In at least 3 of the areas I tried to call up the map, and this resulted in the game freezing completely. Nothing worked, except for some reason the "J" key - which brings up the list of your quests - even ESC didn't work. I had to bring up the Task Master, cancel the game, and then reload the game from my last save.
