1 post • Page 1 of 1
So I tried installing Enderal today. Everything went smoothly until it told me to update the game. So i tried to update the game but I got this error message:
System.FormatException: The input string layout is incorrect.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt64(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Convert.ToInt64(String value)
at Launcher_01.formPanUpdate.checkDownloadOrExtractFile()
at Launcher_01.formPanUpdate.btnDownloadUpdate_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I had the option to continue or close. Both had the same effect of the update not installing.
I tried the following:
-checking if skyrim runs without the mod. (it did)
-uninstalling and reinstalling skyrim and Enderal.
-run as admin
-use the cmd command
-restarted the pc
-turning off my virusscanner and firewall
-deleting the update folder
-changing conf.usr
-putting skyrim.esm in the data folder. (because it told me it couldn't find skyrim.esm). This resulted in the game running, but the buttons in the menu didn't work.
-browsing the internet to see if other people had this problem and solutions. (couldn't find any D:)
Pc specs:
AMD RX 480 8gb
intel quad core i5-6500 @3.20ghz
8gb ram
480gb ssd
windows 10 64-bit
I have added the Laucher.log file if anyone needs it.
Thanks in advance!
NOTE: I had to translate the error message to English so I am not sure if it's free of typos :)
Launcher.log
(128.62 KiB) Downloaded 71 times
