4 posts • Page 1 of 1
Still have Weird Fever
Post by pcoutin »
That one ritual with the sorceress in the... Pyrean ruin, with all the fires and the mercenaries, didn't remove the Weird Fever. It didn't seem to change anything. I still have Weird Fever in the effects list even after the Order's ritual and waking up, and still get Arcane Fever from healing potions and spells.
Is this intended?
Thanks
If you stopped getting arcane fever at the beginning of the game, there would not be much point in having it as a feature so I believe you are supposed to still have it. If I remember right the ritual was just suppoed to get it under control ?
The only thing that happened for me, was that I now have a permanent particle effect on my character.
Not sure its intended to last that long or a bug.
Is this intended?
Thanks
It is intended that you still have the "fever"
because it is more than just the "arcanist fever".
You'll find out during the MQ.
Check out this solution.
