23 posts • Page 1 of 2
I've gotten to the character creation screen and can choose one of the four races, but that's all I can do. I can change anything on the top bar. I've clicked and hit every button on the keyboard.
How to I select the options at the top of the screen? Race, Body , Hair...
The same holds true in the system menu. I can't change the top options.
It would be helpfull if you could open a ticket in our Bugtracker.
You can't login. Only team members have accounts.
Just select the topic in the list on the left of your screen OR simply click on the create button in the top middle.
It would seem that the Flawless Widescreen may have fixed that for me. Running at 2560x1080.
If you play at 21:9 aspect, 3440x1440, when trading with npc, the top and bottom of the trade window get cut off. So you can't see how much coin you have, or how much the vendor has. This also affects just viewing your own inventory. The bottom item gets cut off, and the top heading part gets cut off. Not too big of a deal in inventory, but when trading with NPC's its important. No idea how much coin my char has until I run out spending it.
A simple zoom out a small bit on the UI would fix it. or allow the UI to be affected by the FOV, and a higher fov would help or fix it.
One other thing I ran into, when in the character creation screen, clicking the words for Body, Face etc did nothing. I had to click above them to get it to register the clicks. So a second UI issue with 3440x1440. The positions for clickable parts of the UI are not scaling with this resolution.
Loving the game otherwise.
That's not that simple ;) We can't fix it ourselves. We have no interface programmer at the moment.
Just use the program FlawlessWidescreen.
Thanks, that worked great :)
1440p?
Post by Hidden308 »
I just installed the mod and I went into the settings. I noticed it set my resolution to 2048x1152, but I have a 1440p monitor 2560x1440. I am wondering if I am experience a bug or 1440p has not been implemented yet or it is something or planning to in the future. Would appreciate a answer, thank you.
Re: 1440p?
Post by unmeaty »
It supports 1440p. Make sure you're not in windowed mode (uncheck the box in the launcher).
Re: 1440p?
Post by Hidden308 »
I did exactly just that, but whatever I tried in settings nothing got the 1440p resolution to show up. Just the other one I mentioned.
Re: 1440p?
Post by Topken »
You can always set it via User-define in the settings.
Re: 1440p?
Post by Hidden308 »
I tried that as well. Still does not show up. The 1440p resolution shows up fine on normal skyrim and other games. Just does not on this but that other one like as if it is windowed mode even though I unchecked windowed mode.
Re: 1440p?
Post by Xagul »
Good Lord, 257 times in a row.
You're using an unsupported resolution. Use FlawlessWidescreen, that should fix your issue.
http://forum.sureai.net/viewtopic.php?f=208&t=10027
Re: 1440p?
Post by Hidden308 »
Well I am not using UltraWide. Just the usual 2560x1440p. 3440x1440 21:9 is Ultrawide. I am not Ultrawide. I mention 2560x1440 in my first post. :P
Re: 1440p?
Post by Hidden308 »
Anyone else knows more about this?
2K, 4K Resolution?
Post by Preslavikus »
Hello there! So when I open up the launcher it wants to run in 2194x1234 and gives no option for any other resolution. If I click the One Tweak option all it does is it lets me choose from 10 or so different resolutions the biggest being 1080p. Is there any way to go to 2k or 4k? Maybe from an ini file?
Okay.... After a few minutes of trying to remember how to manually change the resolution of skyrim I have found a solution if anyone is interested in this.
In order to get the desired resolution 2k or 4k, whatever the case all you have to do is edit your pref file in the skyrim documents directory. For anyone who doesnt know where that is, its located in (win10) C:\Users\********\Documents\My Games\Skyrim
******* = your computer's username
Once in the folder you can open the SkyrimPrefs.ini file (if win asks you how to open the program select notepad)
Under [ImageSpace] category you will find the following
bFull Screen=1 -this option is for enabling full screen as you see here
bFXAAEnabled=0 -this option is for fxaa disabled currently
iSize W=3840 -these 2 are your resolution and can be set to whatever you wish your game to run at
iSize H=2160 -not sure how this scales for wide format monitors
Re: 1440p?
Post by Hidden308 »
I guess not. :(
Re: 1440p?
Post by Deathstr0ke_DC »
This is what you're looking for. http://skyrimelder.weebly.com/ini-tweaks.html
Re: 1440p?
Post by Hidden308 »
I tried it didn't work.
Re: 1440p?
Post by mikegray »
Yeah, there's something weird going on with the launcher. I have a 2560x 1440 screen too, and my settings keep on getting knocked back to the same numbers you have: 2048x 1152. Moreover more, the launcher ALSO overwrites any changes I make to SkyrimPrefs.ini - not only resolution settings but also completely unrelated changes. Very annoying.
For a while, there seemed to be nothing I could do to get the game to start at proper resolution - no matter what, I was getting a weird window.
I was able to get it up and going properly by EXITING the Enderal launcher, THEN changing the iSize W and iSize H values (to 2560 and 1440), THEN restarting the launcher, and activating the OneTweak setting in the Launcher. My resolution numbers (greyed out) are STILL at 2048x 1152, but the game does start in borderless window mode.
However, the launcher continues to overwrite changes I make to the .ini file. So far, the only way I've found to protect other changes to SkyrimPrefs.ini is to set the file to read-only - though, of course, that pretty much shuts down the settings function on the Enderal launcher.
