So i'm at the last quest
I have the same problem. but what you say about a the "destroy the beacon option" there is no such option, when you talk to Calia to say that you will destroy the beacon there is only a talk about it not a option that is indicated by = a mark. so this makes me question if there even is a way too choose to destroy it or that they just didn't create the second option.
i hope that someone can confirm that this is the actual case. if not do say so cause then i will have an excuse to play this mod for the third time.
TheBrave18 wrote: [...] so this makes me question if there even is a way too choose to destroy it or that they just didn't create the second option.
Stampfer wrote:As has been correctly suspected already there are two endings. When playing the German version I had the option to destroy the beacon. That option might be tied to your dialogue choices when talking to the guardian. Could just as well be a bug in the English version though.TheBrave18 wrote: [...] so this makes me question if there even is a way too choose to destroy it or that they just didn't create the second option.
EDIT: i did some youtube;) and saw the second ending so i think this is a bug with the english version i am sure i chose the right things but the second option just doesn't show.
Did you try again with the newest patch?
It seems that the second answer was slightly too long - Skyrim has a scroll bug and it will not display an answer if it is too long.
This did not happen in our playtesting - I am not sure why it appeared now as it worked before; well I fixed it and it now should be displayed properly with the newest patch.
Caleb8980 wrote:Did you try again with the newest patch?![]()
