3 posts • Page 1 of 1
Heyy!
I'm wondering if anyone has experimented with importing a creature companion mod from Skyrim into Enderal. Because the follower system for Enderal isn't the same as Skyrim I'm wonder if they're compatible?
I kind of love having a dog or wolf or something tagging along all the time with my ranger characters and wondering if it's possible?
Thanks!
Re: Creature Companions
Post by Chiobe »
I think the problem is rather that the animal mods dont have a related place to be in Enderal, in the same way most companion mods dont work, because you cant find them in Enderal.
It might be possible to work something out with using console commands.
http://www.nexusmods.com/skyrim/mods/12933/? does work with Enderal, so install it along with a companion mod and try it.
I assume the console commands are the same: http://elderscrolls.wikia.com/wiki/Cons ... /Followers
@Chiobe, I'll have to try EFF with them ... I tried loading Lola in earlier today {http://www.nexusmods.com/skyrim/mods/59174/?} and she did the player.placeatme just fine, showed up and idled but won't follow even though the little message in the upper left corner appeared -- Hopefully EFF will fix that, if not I'll have to check in the scripting and see if there's a tweak I can make to get that to trigger correctly!
