15 posts • Page 1 of 2
I'm apparently not that good at riddles. My current riddle and what I have attempted so far below:
"At the beginning of the current, in the west a grand stone with an elevated, bare tree."
I figured the first bit meant either the river mouth or the river's source, so I poked around up and down the two rivers near Riverville looking for leafless trees on hilltops. While I found a leafless tree at the river mouth of the river to the west of town (by a circle of stones with a skeleton in the middle) it wasn't elevated and I didn't see any new riddles nearby. I wasn't able to find any other promising trees farther up that west river or anywhere along the west branch of the river that runs through the town.
I also checked around the western island in the bay in case that's what the riddle meant, but no luck there either. Frankly I'm at a loss. I must have missed something, but I have no idea what.
Re: Secrets from the Can
Post by Xagul »
Yes, it can be a bit confusing. However, this is how it should work:
On the same level, where the river runs into the sea is farm where you found the boy. Behind the farm, in western direction is a mountainous area and atop of one mountain - quite good to see - is a large bare tree. Climb up there and look for a ruin in the (farther) vicinity of the tree.
Hope that helps you.
Post by Kemott »
I can't figure out the first riddle, about the shrine. Where do I have to look? Couldn;t find anything inside or outside of it.
There is a shrine right at the sea, next to the wheat field where the boy tends to hang around. On the backside of the altar is a little stone plaque with the next part of the riddle on it.
I think it is not the shrine you are talking about (it has no 'inside'). You can see the actual shrine from where the can is. It is a short way north of it, even illuminated with candles.
edit: ninja'd
Thank you very much!
Post by Kamawell »
For the life of me I can't find the place described on the note. I think the kid said something about the shrine behind his house. Could someone give me a hint please?
Post by Seppl »
The shrine is obviously the ... yes, shrine directly near the beach... and from this place you should see the tree in the nord-west. Around the tree you should find the next hint... i found it not... but when you search there in a bigger circle you can find the treasure chest without this hint...
Thanks! I was looking for something more... pagan I guess -0 not quite sure why.
