39 posts • Page 4 of 4
Danke. Hab das Spiel gestartet, und nun, für eine Sekunde war Musik da.... Da wars wieder weg.
[[ Starting Launcher ]]
Log started at 2016/07/26 18:34:15
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Please use our Bugtracker at http://forum.sureai.net/tracker.php to report this problem.
Release ID: A33
Release version: Skyrim Classic
Build date: 26.07.2016 18:34:13
Creation date: 26.07.2016 14:41:24
App start location: C:\Games\steamapps\common\Skyrim\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions: 4.6 or later
Language: DE
Build version: 1.0.0.0
Game version: 1.0.2.0
Internet connection: False
Installation status: False
Steam status: True
OneTweak status: True
Directory search status: True
Last external startup path: C:\Users\Emre\Downloads\
Last external executable: Enderal Launcher.exe
Backup path Enderal: path
Backup path Skyrim: C:\\Games\SteamApps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<18:34:15> Conf - Initialize conf file
<18:34:15> Conf - Initialize conf file [DONE]
<18:34:15> Conf - Save conf file
<18:34:15> Conf - Save conf file [DONE]
<18:34:15> Conf - Initialize Version
<18:34:15> Conf - Checking Environment
<18:34:15> Conf - Checking Environment [DONE]
<18:34:15> Func - RWP: C:\Games\SteamApps\common\Skyrim\EnderalLauncher\system\ recursive
<18:34:15> Func - RWP: C:\Games\SteamApps\common\Skyrim\EnderalLauncher\update\ recursive
<18:34:15> Func - RWP: C:\Games\SteamApps\common\Skyrim\EnderalLauncher\backup\ top level
<18:34:15> Func - RWP: C:\Games\SteamApps\common\Skyrim\ top level
<18:34:15> Main - Initialize Unpatcher
<18:34:15> Unpa - Start cleanup
<18:34:15> Main - Unpatcher [DONE]
<18:34:15> Main - Create environment
<18:34:15> Main - Create environment [DONE]
<18:34:15> Main - Initialize network
<18:34:15> Net - Connection enabled in settings
<18:34:15> Net - System is connected to network
<18:34:15> Net - Try to establish server connection thread
<18:34:15> Net - Thread STARTED
<18:34:15> Main - Initialize network [DONE]
<18:34:15> Main - Initialize intervall
<18:34:15> Main - Initialize intervall [DONE]
<18:34:15> Net - Choose server
<18:34:15> Main - Initialize PanBase
<18:34:15> Net - Connect to dl4
<18:34:15> Net - Server connection attempt #1
<18:34:15> Main - Initialize PanBase [DONE]
<18:34:15> Main - Initialize CPanel
<18:34:15> Cp - Cp Initialisation
<18:34:15> Cp - No connection to server established yet, try again in 5 seconds...
<18:34:15> Main - Initialize CPanel [DONE]
<18:34:15> Cp - Check Cp file
<18:34:15> Cp - Read old Cp file
<18:34:15> Net - Connection port: 80
<18:34:15> Net - Connection default port: True
<18:34:15> Net - Connection proxy bypassed: True
<18:34:15> Cp - Start Cp pic checker
<18:34:15> Cp - All pics found
<18:34:15> Conf - Hardware Scan:
<18:34:15> Conf - CPU: Intel(R) Core(TM) i7-4720HQ CPU @ 2.60GHz, Speed: 2601, Cores: 8
<18:34:15> Conf - GPU: Intel(R) HD Graphics 4600, Memory: 0 GB
<18:34:15> Conf - RAM: 7 GB
<18:34:15> Conf - DISC: 756381 MB
<18:34:17> Net - Connection OK
<18:34:17> Net - HttpWeb: Start listing available versions:
<18:34:17> Net - HttpWeb: 1.0.0.2 S 1
<18:34:17> Net - HttpWeb: 1.0.0.3 M 1
<18:34:17> Net - HttpWeb: 1.0.0.4 S 1
<18:34:17> Net - HttpWeb: 1.0.0.5 M 1
<18:34:17> Net - HttpWeb: 1.0.0.6 S 1
<18:34:17> Net - HttpWeb: 1.0.0.7 M 1
<18:34:17> Net - HttpWeb: 1.0.0.8 S 1
<18:34:17> Net - HttpWeb: 1.0.0.9 M 1
<18:34:17> Net - HttpWeb: 1.0.1.3 S 1
<18:34:17> Net - HttpWeb: 1.0.1.4 M 1
<18:34:17> Net - HttpWeb: 1.0.1.7 S 1
<18:34:17> Net - HttpWeb: 1.0.1.8 S 1
<18:34:17> Net - HttpWeb: 1.0.1.9 M 1
<18:34:17> Net - HttpWeb: 1.0.2.0 S 1
<18:34:17> Net - HttpWeb: End
<18:34:20> Settings - Settings saved
<18:34:20> Cp - Retry thread started attempt #1
<18:34:20> Cp - Try to compare server with local file
<18:34:20> Cp - Connection port: 80
<18:34:20> Cp - Connection default port: True
<18:34:20> Cp - Connection proxy bypassed: True
<18:34:20> Cp - Connection OK
<18:34:20> Cp - 04.07.2016 00:09:01 10.07.2016 16:02:54
<18:34:20> Cp - Up-to-date
<18:34:20> Cp - Check Cp file
<18:34:20> Cp - Read old Cp file
<18:34:20> Cp - Start Cp pic checker
<18:34:20> Cp - All pics found
<18:34:35> Settings - Settings saved
<18:35:07> Settings - Settings saved
<18:37:02> Conf - Save conf file
<18:37:02> Conf - Save conf file [DONE]
<18:37:02> Exit
Na zumindest kein Launcher abhängiger Fehler, das ist schon mal gut, danke fürs testen. Vielleicht willst du ja mal eine Neuinstallation in Betracht ziehen.
Wie soll ich Enderal genau Installieren? Skyrim deinstallieren, Ordner löschen, Skyrim wieder installieren und dann Enderal? Order würde es genügen Wenn ich nur übern Launcher Enderal de und wieder installiere?
Als erster Test wäre es gut Enderal zu deinstallieren und ein Backup davon aufzuheben. Dann gucken wie Skyrim läuft, ob es dort auch Probleme mit dem Sound gibt.
Wenn ja, dann überprüfe noch mal die Skyrim.ini Datei. Gibt es dort diesen Eintrag und sieht er folgendermaßen aus:
[Archive]
sResourceArchiveList=Skyrim - Misc.bsa, Skyrim - Shaders.bsa, Skyrim - Textures.bsa, Skyrim - Interface.bsa, Skyrim - Animations.bsa, Skyrim - Meshes.bsa, Skyrim - Sounds.bsa
sResourceArchiveList2=Skyrim - Voices.bsa, Skyrim - VoicesExtra.bsa
Wenn nein, dann ändere ihn zu dem obigen Eintrag ab und teste ob es immer noch zu Problemen mit den Sound kommt.
Sollte es dennoch Probleme geben, probiere es mit einer Steam Reparatur deines Skyrim Verzeichnis. Anschließend teste nochmal was der Sound in Skyrim macht.
Wenns dann klappt, dann installiere Enderal erneut durch das zuvor erstellte Backup.
Wenn es dann wieder Sound Probleme gibt, entferne Enderal komplett ohne Backup und teste anschließend, ob der Sound in Skyrim weiterhin glatt läuft.
Wenn das der Fall ist, dann mach eine saubere Installation von Enderal durch das Installationspaket und patche anschließend.
Es funktioniert immer noch nicht.
Na damit kann ich auch nix anfangen, dann kann ich nur sagen, da stimmt etwas grundsätzlich nicht bei deinem System, wenn nicht mal Skyrim läuft.
Oh sry, ich hätt wohl sagen sollen das in Skyrim alles prima läuft, in enderal fehlt nur die Hintergrundmusik. In skyrim ist sie da.
Check mal deine \My Games\Skyrim\Skyrim.ini auf folgende Einträge und füge sie ein, sollten sie nicht existieren.
sResourceArchiveList2=Enderal - Misc.bsa, Enderal - Meshes.bsa, Enderal - Sounds.bsa, Enderal - Textures.bsa, Enderal - Textures2.bsa, Enderal - Textures3.bsa, Enderal - Textures4.bsa, Enderal - Voices.bsa
Auch damits hats nicht Funktioniert. Aber in einem anderem Thread hatte Tilliboy einen Lösungsvorschlag. Man solle das""RemoveMusic _00E_SilenceLongTransitionHighPriority" in die Konsole eintippen und bestätigen. Und siehe da die Musik spielt wieder. Danke jedenfalls für die Bemühungen das Problem mit der Musik zu lösen. :thumbsup:
