sontifx wrote:It was the Vivid ENB on the NexusEolath wrote:What ENB did you use to increase the FPS?
Problem is I only have a 60hz monitor so I would like to cap it to 60 but I am unable to.
Did below from: https://www.reddit.com/r/skyrimmods/wik ... ners_guide but I notice no difference at all, how do I check if it is enabled?
Download the archive to the newly created folder "Skyrim Modding/ENB Manager/Versions/2xx"
Once downloaded, right-click the ENBseries archive and select "Extract Here..."
Open the Wrapper Version folder and select ONLY these files:
enbhost.exe
enblocal.ini
d3d9.dll
Copy and paste these three files into your main Skyrim directory
Open the enblocal.ini and edit the values according to this page
ArachnidSoul wrote:This is my first post on this forum. I signed up for an account just so I could say that Deathstr0ke_DC ini edit files worked really well for me. Now I can run this game at 4k resolution on ultra settings and for the most part stay at 60 FPS. Which is a better result than i was getting before installing those ini edits...even when I factor in that I was playing at only 1080 resolution then. So If you have a nice rig, I suggest you back up your Skyrim and SkyrimPref ini files, and then try out Deathstr0ke_DC ini edits. Thank you for working on them Deathstr0ke_DC.
Still trying to find ways to improve it further too. Appreciate the feedback!
I am always having low fps at this town.
https://s20.postimg.io/taeyp37or/20160829200724_1.jpg
I am running
Windows 10.
FX8320, R9 FURY.
I tried lowering global view distance to 1, at it still gives between 20-30 fps.
Normally I can run things even at 1440p with this GPU so i doubt it's on my end.
I am running
Windows 10.
FX8320, R9 FURY.
I noticed the other thread that was making some progress on helping me with my FPS drops was locked.
I wanted to open another to collaborate together on how to avoid the random drastic FPS drops I and some others are experiencing.
Here's the thread;
https://forum.sureai.net/viewtopic.php?f=208&t=9781
So after trying the .ini files it got a little better but still, odd drop from 60 to less than 30 FPS just turning around to face the opposite direction is killing the game for me.
Had anyone got any other suggestions on how to fix this issue or alleviate it in some ways?
Here's the thread;
I have like 10-20 fps everywhere where I look. Do you know any way i can get an 30-40 ??
Please help !!!!!
Please help !!!!!
Eolath wrote:Yeah, I feared it'd be engine related. It's not a big issue by any stretch of the imagination. I'll keep fiddling with the settings and see if I can add a couple FPS here and there.
So I gave up on the mod, no matter what I did besides turning everything to low, I just couldn't maintain a steady and acceptable frame rate. I really killed the game for me and sadly after days of trying everything I could find, I'll have to pass on Enderal..maybe in a couple years when I have a ridiculously powerful PC I'll try again...so sad.
