Also is there a console command to give myself a keystone so I can continue on with this quest?
Where are these keys supposed to be found aside from the den at the end of the crypt in Gilead....in the dungeons the keyhole columns let you into?....is so then perhaps one was disloged when I fire balled some skelletons in the dungeon where I found the first of 3 statues/artifacts
Hi
Its actually pointing to where you should go. That first place is where you should have picked up three keystones.
but when I click on it it does nothing???
player.additem 025b33 1
And I've fixed it now, so the bug will be gone in the next patch. Thanks for reporting!
arvisrend wrote:player.additem 025b33 1
Thanks heaps, your a legend
Far out now I have all three statues but no matter how many times I drop the on the circles nothing happens
this quest has buged out on me. Since I entered the Keyhole column on the west of the map first and used the keystone key I found in the crypt in Gilead I had no keystone to use on the keyhole column near Fursanden, i had to use the console command player.additem 025b33 1 to get a keystone to enter it. I didn't pick up the 3 keystones in that dungeon that were on the table with the note because I couldn't see them because they wer almost invisible. Now that I have picked up all three statues and used the console command on the remaining 2 keyhole columns to gain access to get the statues and I'm back where I have to place the statues in the circles the statues do nothing when droped in the circles....quest is completely bugged and broken for me now.
Here is the current saved game, hope yu can fix this one.
Save 620 - misterman - Hidden Temple Complex, Level 34, Playing Time 105.56.13.rar
(1.73 MiB) Downloaded 248 times
Save game attached
Save 13 - maximus - Gruft von Giliad, Level 16, Playing Time 29.31.27.ess
(2.12 MiB) Downloaded 262 times
Nevermind, I disabled all my mods and this time it worked
