28 posts • Page 2 of 2
Re: Can't Update the Game
Post by Hoxyd »
The launcher log could help here. You can find it at: ..\Skyrim\EnderalLauncher\system\log\Launcher.log
"Internet connection: True
Installation status: False
Steam status: True
OneTweak status: True
Directory search status: True
Master found: True
SKSE found: True"
I'm guessing I need to figure out how to change the Installation status to "True"?
The best would be to attach the whole log. Your private stuff should be masked automatically.
Alright
[+] Log
[[ Starting Launcher ]]
Log started at 2017/04/13 23:31:06
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A58
Release version: Skyrim Classic
Build date: 13/04/2017 11:31:06 PM
Creation date: 13/04/2017 11:30:44 PM
App start location: C:\ *** MASKED USERPATH *** \Downloads\
App game folder: Downloads\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.0.0
Steam status: True
Master found: True
SKSE found: True
Last external startup path:
Last external executable:
Backup path Enderal: path
Backup path Skyrim: path
> Start logging:
<23:31:06> Conf - Initialize conf file
<23:31:07> Conf - Unpack Readme
<23:31:07> Conf - Initialize conf file [DONE]
<23:31:07> Conf - Save conf file
<23:31:07> Conf - Save conf file [DONE]
<23:31:07> Conf - Checking Environment
<23:31:07> Conf - Creating shortcut (C:\ *** MASKED USERPATH *** \Downloads\Start Enderal.lnk)
<23:31:09> Conf - Creating shortcut [DONE]
<23:31:11> Conf - Save conf file
<23:31:11> Conf - Save conf file [DONE]
<23:31:11> Exit(A)
Log started at 2017/04/13 23:31:11
Release ID: A58
Creation date: 13/04/2017 11:31:07 PM
App start location: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\
App game folder: Skyrim\
Language: EN
Steam status: True
Master found: True
SKSE found: True
Last external startup path: C:\ *** MASKED USERPATH *** \Downloads\
Last external executable: Enderal Launcher.exe
> Start logging:
<23:31:12> Conf - Initialize conf file
<23:31:12> Conf - Unpack Readme
<23:31:12> Conf - Initialize conf file [DONE]
<23:31:12> Conf - Save conf file
<23:31:12> Conf - Save conf file [DONE]
<23:31:12> Conf - Checking Environment
<23:31:12> Conf - Checking Environment [DONE]
<23:31:12> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<23:31:12> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<23:31:12> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<23:31:12> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<23:31:12> Main - Initialize Unpatcher
<23:31:12> Main - Unpatcher [DONE]
<23:31:12> Main - Create environment
<23:31:12> Main - Create environment [DONE]
<23:31:12> Main - Initialize network
<23:31:12> Net - Connection enabled in settings
<23:31:12> Net - System is connected to network
<23:31:12> Net - Try to establish server connection thread
<23:31:12> Net - Thread STARTED
<23:31:12> Main - Initialize network [DONE]
<23:31:12> Net - Choose server
<23:31:12> Main - Initialize intervall [DONE]
<23:31:12> Net - Server connection attempt #1
<23:31:12> Main - Initialize PanBase [DONE]
<23:31:12> Main - Initialize CPanel
<23:31:12> Cp - Cp Initialisation
<23:31:12> Net - Connection port: 80
<23:31:12> Main - Initialize CPanel [DONE]
<23:31:12> Cp - Check Cp file
<23:31:12> Cp - Abort: Cp does not exist
<23:31:12> Net - HttpWeb: Web Exception occurred!
Exception type: Could not connect to server
Exception type: System.Net.WebException
Exeption name : WebException
Message : Unable to connect to the remote server
Source : System
Funtion : System.Net.WebResponse GetResponse()
Result : -2146233079
Data : System.Collections.ListDictionaryInternal
Stacktrace:
at System.Net.HttpWebRequest.GetResponse()
at Launcher_01.cs_Network.checkOnlineFiles(String server)
<23:31:13> Conf - Hardware Scan:
<23:31:13> Conf - CPU: AMD FX(tm)-6350 Six-Core Processor , Speed: 4200, Cores: 6
<23:31:13> Conf - GPU: NVIDIA GeForce GTX 1070, Memory: 4 GB
<23:31:13> Conf - RAM: 16 GB
<23:31:13> Conf - DISC: 107187 MB
<23:31:17> Cp - Retry thread started attempt #1
<23:31:17> Cp - No connection to server established yet, try again in 5 seconds...
<23:31:17> Cp - Check Cp file
<23:31:17> Cp - Abort: Cp does not exist
<23:31:20> SetUp - fillRecommendedSysLabels
<23:31:22> Cp - Retry thread started attempt #2
<23:31:22> Cp - No connection to server established yet, try again in 5 seconds...
<23:31:22> Cp - Check Cp file
<23:31:22> Cp - Abort: Cp does not exist
<23:31:22> SetUp - Choose installationfile
<23:31:27> SetUp - Choose backup
<23:31:27> Cp - Retry thread started attempt #3
<23:31:27> Cp - No connection to server established yet, try again in 5 seconds...
<23:31:27> Cp - Check Cp file
<23:31:27> Cp - Abort: Cp does not exist
<23:31:28> SetUp - Ready for installation
<23:31:29> SetUp - Started Create Skyrim backup command
<23:31:29> SetUp - Started, moving files:3626 At rate:0.0275786
<23:31:29> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\ top level
<23:31:30> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Interface\ top level
<23:31:30> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\animations\apsexidles\ top level
<23:31:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\behaviors\ top level
<23:31:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\character assets\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\character assets female\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\characters\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\actors\character\characters female\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\armor\aeon\strapon\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\cumshot\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\squirt\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\squirt\zaz fluidity\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\music\ap skyrim\normalsex\ top level
<23:31:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\scripts\ top level
<23:31:32> Cp - Retry thread started attempt #4
<23:31:32> Cp - No connection to server established yet, try again in 5 seconds...
<23:31:32> Cp - Check Cp file
<23:31:32> Cp - Abort: Cp does not exist
<23:31:32> Cp - Retry thread ended to many attempts
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\seq\ top level
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\skse\plugins\ top level
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\fx\ap skyrim\normalsex\ top level
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\dlc1femalevampire\ top level
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\dlc1malevampire\ top level
<23:31:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\dlc1seranavoice\ top level
<23:31:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleargonian\ top level
<23:31:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalecommander\ top level
<23:31:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalecommoner\ top level
<23:31:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalecondescending\ top level
<23:31:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalecoward\ top level
<23:31:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaledarkelf\ top level
<23:31:37> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleelfhaughty\ top level
<23:31:37> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleeventoned\ top level
<23:31:38> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalekhajiit\ top level
<23:31:39> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalenord\ top level
<23:31:39> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleoldgrumpy\ top level
<23:31:40> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleoldkindly\ top level
<23:31:40> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleorc\ top level
<23:31:41> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleshrill\ top level
<23:31:41> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalesoldier\ top level
<23:31:42> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femalesultry\ top level
<23:31:43> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniqueastrid\ top level
<23:31:43> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniqueazura\ top level
<23:31:43> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniqueboethiah\ top level
<23:31:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquedelphine\ top level
<23:31:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniqueelenwen\ top level
<23:31:45> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniqueghost\ top level
<23:31:45> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquekarliah\ top level
<23:31:46> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquemaven\ top level
<23:31:46> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquemephala\ top level
<23:31:46> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquemeridia\ top level
<23:31:47> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquemirabelleervine\ top level
<23:31:48> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquenamira\ top level
<23:31:48> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquenightmother\ top level
<23:31:48> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquenocturnal\ top level
<23:31:48> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquevaermina\ top level
<23:31:49> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleuniquevex\ top level
<23:31:50> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\femaleyoungeager\ top level
<23:31:50> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleargonian\ top level
<23:31:50> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malebandit\ top level
<23:31:51> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malebrute\ top level
<23:31:51> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malecommander\ top level
<23:31:51> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malecommoner\ top level
<23:31:51> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malecommoneraccented\ top level
<23:31:52> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malecondescending\ top level
<23:31:52> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malecoward\ top level
<23:31:52> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maledarkelf\ top level
<23:31:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maledrunk\ top level
<23:31:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleelfhaughty\ top level
<23:31:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleeventoned\ top level
<23:31:54> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleeventonedaccented\ top level
<23:31:54> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleforsworn\ top level
<23:31:54> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleguard\ top level
<23:31:54> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malekhajiit\ top level
<23:31:55> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malenord\ top level
<23:31:55> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malenordcommander\ top level
<23:31:55> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleoldgrumpy\ top level
<23:31:55> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleoldkindly\ top level
<23:31:56> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleorc\ top level
<23:31:56> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleslycynical\ top level
<23:31:56> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malesoldier\ top level
<23:31:56> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueamaundmotierre\ top level
<23:31:56> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueancano\ top level
<23:31:57> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquearngeir\ top level
<23:31:57> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueaventusaretino\ top level
<23:31:57> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquebrynjolf\ top level
<23:31:57> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquecicero\ top level
<23:31:58> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueclavicusvile\ top level
<23:31:58> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquedbguardian\ top level
<23:31:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquedbspectrallachance\ top level
<23:31:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquedelvinmallory\ top level
<23:31:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueemperor\ top level
<23:31:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueesbern\ top level
<23:32:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquegallus\ top level
<23:32:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquegalmar\ top level
<23:32:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueghost\ top level
<23:32:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueghostsvaknir\ top level
<23:32:01> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquehadvar\ top level
<23:32:01> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquehermaeusmora\ top level
<23:32:01> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquehircine\ top level
<23:32:01> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquekodlakwhitemane\ top level
<23:32:02> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquemalacath\ top level
<23:32:02> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquemehrunesdagon\ top level
<23:32:02> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquemercerfrey\ top level
<23:32:03> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquemgaugur\ top level
<23:32:03> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquemolagbal\ top level
<23:32:03> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquenazir\ top level
<23:32:03> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueperyite\ top level
<23:32:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueseptimus\ top level
<23:32:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquesheogorath\ top level
<23:32:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniquetullius\ top level
<23:32:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleuniqueulfric\ top level
<23:32:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\malewarlock\ top level
<23:32:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\maleyoungeager\ top level
<23:32:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialfemaleuniquegormlaith\ top level
<23:32:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniqueborri\ top level
<23:32:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniqueeinarth\ top level
<23:32:06> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniquefelldir\ top level
<23:32:06> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniquehakon\ top level
<23:32:06> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniquetsun\ top level
<23:32:06> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\sound\voice\ap skyrim.esm\specialmaleuniquewulfgar\ top level
<23:32:06> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Strings\ top level
<23:32:07> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\armor\aeon\strapon\ top level
<23:32:07> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\cumload\ top level
<23:32:07> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\cumshot\ top level
<23:32:07> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\squirt\ top level
<23:32:07> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Video\ top level
<23:32:09> SetUp - Started Install Enderal command
<23:32:09> SetUp - Source gz/zip found with size: 8427964531
<23:32:09> SetUp - Try start archive extraction
<23:32:09> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\Data/ top level
<23:32:09> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<23:32:09> SetUp - Started, installing files:204 At rate:0.4901961
<23:42:27> Net - System is connected to network
<23:42:27> Net - Try to establish server connection thread
<23:42:27> Net - Thread STARTED
<23:42:27> Net - Choose server
<23:42:27> Net - Connect to [DL2]
<23:42:27> Net - Server connection attempt #2
<23:42:27> Net - Connection port: 80
<23:42:27> Net - Connection default port: True
<23:42:27> Net - Connection proxy bypassed: True
<23:42:27> Net - HttpWeb: Web Exception occurred!
Source : System
Stacktrace:
<23:42:28> SetUp - Enderal Installation done
<01:46:45> Conf - Save conf file
<01:46:45> Conf - Save conf file [DONE]
<01:46:45> Exit(A)
Log started at 2017/04/14 13:24:32
Release ID: A58
Language: EN
Installation status: True
Steam status: True
Master found: False
SKSE found: True
Backup path Skyrim: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<13:24:32> Conf - Initialize conf file
<13:24:32> Conf - Initialize conf file [DONE]
<13:24:32> Conf - Save conf file
<13:24:32> Conf - Save conf file [DONE]
<13:24:32> Conf - Checking Environment
<13:24:32> Conf - Checking Environment [DONE]
<13:24:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<13:24:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<13:24:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<13:24:32> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<13:24:32> Main - Initialize Unpatcher
<13:24:32> Unpa - Start cleanup
<13:24:32> Main - Unpatcher [DONE]
<13:24:32> Main - Create environment
<13:24:32> Main - Create environment [DONE]
<13:24:32> Main - Initialize network
<13:24:32> Net - Connection enabled in settings
<13:24:32> Net - System is connected to network
<13:24:32> Net - Try to establish server connection thread
<13:24:32> Net - Thread STARTED
<13:24:32> Main - Initialize network [DONE]
<13:24:32> Net - Choose server
<13:24:32> Main - Initialize intervall [DONE]
<13:24:32> Net - Server connection attempt #1
<13:24:32> Main - Initialize PanBase [DONE]
<13:24:32> Main - Initialize CPanel
<13:24:32> Cp - Cp Initialisation
<13:24:32> Net - Connection port: 80
<13:24:32> Main - Initialize CPanel [DONE]
<13:24:32> Cp - Check Cp file
<13:24:32> Cp - Abort: Cp does not exist
<13:24:33> Net - HttpWeb: Web Exception occurred!
Source : System
Stacktrace:
<13:24:33> Conf - Hardware Scan:
<13:24:33> Conf - CPU: AMD FX(tm)-6350 Six-Core Processor , Speed: 4200, Cores: 6
<13:24:33> Conf - GPU: NVIDIA GeForce GTX 1070, Memory: 4 GB
<13:24:33> Conf - RAM: 16 GB
<13:24:33> Conf - DISC: 97791 MB
<13:24:37> Cp - Retry thread started attempt #1
<13:24:37> Cp - No connection to server established yet, try again in 5 seconds...
<13:24:38> Cp - Check Cp file
<13:24:38> Cp - Abort: Cp does not exist
<13:24:43> Cp - Retry thread started attempt #2
<13:24:43> Cp - No connection to server established yet, try again in 5 seconds...
<13:24:43> Cp - Check Cp file
<13:24:43> Cp - Abort: Cp does not exist
<13:24:48> Cp - Retry thread started attempt #3
<13:24:48> Cp - No connection to server established yet, try again in 5 seconds...
<13:24:48> Cp - Check Cp file
<13:24:48> Cp - Abort: Cp does not exist
<13:24:53> Cp - Retry thread started attempt #4
<13:24:53> Cp - No connection to server established yet, try again in 5 seconds...
<13:24:53> Cp - Check Cp file
<13:24:53> Cp - Abort: Cp does not exist
<13:24:53> Cp - Retry thread ended to many attempts
<13:30:25> Conf - Save conf file
<13:30:25> Conf - Save conf file [DONE]
<13:30:25> Exit(A)
Log started at 2017/04/14 13:30:30
Release ID: A58
Language: EN
Steam status: True
Master found: False
SKSE found: True
> Start logging:
<13:30:30> Conf - Initialize conf file
<13:30:30> Conf - Initialize conf file [DONE]
<13:30:30> Conf - Save conf file
<13:30:31> Conf - Save conf file [DONE]
<13:30:31> Conf - Checking Environment
<13:30:31> Conf - Checking Environment [DONE]
<13:30:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<13:30:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<13:30:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<13:30:31> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<13:30:31> Main - Initialize Unpatcher
<13:30:31> Unpa - Start cleanup
<13:30:31> Main - Unpatcher [DONE]
<13:30:31> Main - Create environment
<13:30:31> Main - Create environment [DONE]
<13:30:31> Main - Initialize network
<13:30:31> Net - Connection enabled in settings
<13:30:31> Net - System is connected to network
<13:30:31> Net - Try to establish server connection thread
<13:30:31> Net - Thread STARTED
<13:30:31> Main - Initialize network [DONE]
<13:30:31> Net - Choose server
<13:30:31> Main - Initialize intervall [DONE]
<13:30:31> Net - Server connection attempt #1
<13:30:31> Main - Initialize PanBase [DONE]
<13:30:31> Main - Initialize CPanel
<13:30:31> Cp - Cp Initialisation
<13:30:31> Net - Connection port: 80
<13:30:31> Main - Initialize CPanel [DONE]
<13:30:31> Cp - Check Cp file
<13:30:31> Cp - Abort: Cp does not exist
<13:30:31> Conf - Hardware Scan:
<13:30:31> Conf - CPU: AMD FX(tm)-6350 Six-Core Processor , Speed: 4200, Cores: 6
<13:30:31> Conf - GPU: NVIDIA GeForce GTX 1070, Memory: 4 GB
<13:30:31> Conf - RAM: 16 GB
<13:30:31> Conf - DISC: 99062 MB
<13:30:31> Net - HttpWeb: Web Exception occurred!
Source : System
Stacktrace:
<13:30:35> Net - Connection Off
<13:30:36> Cp - Retry thread started attempt #1
<13:30:36> Cp - No connection to server established yet, try again in 5 seconds...
<13:30:36> Cp - Check Cp file
<13:30:36> Cp - Abort: Cp does not exist
<13:30:41> Cp - Retry thread started attempt #2
<13:30:41> Cp - No connection to server established yet, try again in 5 seconds...
<13:30:41> Cp - Check Cp file
<13:30:41> Cp - Abort: Cp does not exist
<13:30:43> Net - Connection On
<13:30:46> Cp - Retry thread started attempt #3
<13:30:46> Cp - No connection to server established yet, try again in 5 seconds...
<13:30:46> Cp - Check Cp file
<13:30:46> Cp - Abort: Cp does not exist
<13:30:49> Conf - Save conf file
<13:30:49> Conf - Save conf file [DONE]
<13:30:49> Exit(A)
Log started at 2017/04/14 13:33:34
Release ID: A58
Language: EN
Steam status: True
Master found: False
SKSE found: True
Last external startup path: 0
Last external executable: 0
> Start logging:
<13:33:34> Conf - Initialize conf file
<13:33:34> Conf - Unpack Readme
<13:33:34> Conf - Initialize conf file [DONE]
<13:33:34> Conf - Save conf file
<13:33:34> Conf - Save conf file [DONE]
<13:33:34> Conf - Checking Environment
<13:33:34> Conf - Checking Environment [DONE]
<13:33:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<13:33:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<13:33:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<13:33:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<13:33:34> Main - Initialize Unpatcher
<13:33:34> Main - Unpatcher [DONE]
<13:33:34> Main - Create environment
<13:33:35> Main - Create environment [DONE]
<13:33:35> Main - Initialize network
<13:33:35> Net - Connection enabled in settings
<13:33:35> Net - System is connected to network
<13:33:35> Net - Try to establish server connection thread
<13:33:35> Net - Thread STARTED
<13:33:35> Main - Initialize network [DONE]
<13:33:35> Net - Choose server
<13:33:35> Main - Initialize intervall [DONE]
<13:33:35> Net - Server connection attempt #1
<13:33:35> Main - Initialize PanBase [DONE]
<13:33:35> Main - Initialize CPanel
<13:33:35> Cp - Cp Initialisation
<13:33:35> Net - Connection port: 80
<13:33:35> Main - Initialize CPanel [DONE]
<13:33:35> Cp - No connection to server established yet, try again in 5 seconds...
<13:33:35> Cp - Check Cp file
<13:33:35> Cp - Abort: Cp does not exist
<13:33:35> Net - HttpWeb: Web Exception occurred!
Source : System
Stacktrace:
<13:33:36> Conf - Hardware Scan:
<13:33:36> Conf - CPU: AMD FX(tm)-6350 Six-Core Processor , Speed: 4200, Cores: 6
<13:33:36> Conf - GPU: NVIDIA GeForce GTX 1070, Memory: 4 GB
<13:33:36> Conf - RAM: 16 GB
<13:33:36> Conf - DISC: 98871 MB
<13:33:40> Cp - Retry thread started attempt #1
<13:33:40> Cp - No connection to server established yet, try again in 5 seconds...
<13:33:40> Cp - Check Cp file
<13:33:40> Cp - Abort: Cp does not exist
<13:33:42> SetUp - fillRecommendedSysLabels
<13:33:45> SetUp - Choose installationfile
<13:33:45> Cp - Retry thread started attempt #2
<13:33:45> Cp - No connection to server established yet, try again in 5 seconds...
<13:33:45> Cp - Check Cp file
<13:33:45> Cp - Abort: Cp does not exist
<13:33:50> Conf - Save conf file
<13:33:50> Conf - Save conf file [DONE]
<13:33:50> Exit(A)
Log started at 2017/04/14 13:33:59
Release ID: A58
Language: EN
Steam status: True
Master found: False
SKSE found: True
> Start logging:
<13:33:59> Conf - Initialize conf file
<13:33:59> Conf - Unpack Readme
<13:33:59> Conf - Initialize conf file [DONE]
<13:33:59> Conf - Save conf file
<13:33:59> Conf - Save conf file [DONE]
<13:33:59> Conf - Checking Environment
<13:33:59> Conf - Checking Environment [DONE]
<13:33:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<13:33:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<13:33:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<13:33:59> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<13:33:59> Main - Initialize Unpatcher
<13:33:59> Main - Unpatcher [DONE]
<13:33:59> Main - Create environment
<13:33:59> Main - Create environment [DONE]
<13:33:59> Main - Initialize network
<13:33:59> Net - Connection enabled in settings
<13:34:00> Net - System is connected to network
<13:34:00> Net - Try to establish server connection thread
<13:34:00> Net - Thread STARTED
<13:34:00> Main - Initialize network [DONE]
<13:34:00> Net - Choose server
<13:34:00> Main - Initialize intervall [DONE]
<13:34:00> Net - Server connection attempt #1
<13:34:00> Main - Initialize PanBase [DONE]
<13:34:00> Main - Initialize CPanel
<13:34:00> Cp - Cp Initialisation
<13:34:00> Net - Connection port: 80
<13:34:00> Cp - No connection to server established yet, try again in 5 seconds...
<13:34:00> Net - Connection proxy bypassed: True
<13:34:00> Cp - Check Cp file
<13:34:00> Cp - Abort: Cp does not exist
<13:34:00> Net - HttpWeb: Web Exception occurred!
Sorry but I couldn't fit the whole thing in, but honestly I'm pretty sure it just repeats itself after a while
Post by urst »
upload it as an attachment
( there's an option for that in the full "answering panel") :)
(and for a spoiler to work you need some word/letter/anything behind the = in [spoiler=] :) )
_______
also, as suggested by Kermit61, do you happen to use a VPN server?
maybe that's somehow interfering?
Post by Hoxyd »
Ok, unfortunately not even the exception handler knows whats wrong with your connection. It's the error code for an unknown exception.
Source : System
Stacktrace:
So no real solution on the launcher side. But you tried so hard, you can download the patches also manually:
1. http://dl1.sureai.net/files/pro/enderal ... eralUpdate_[1.1.3.0][F][1]_EN.zip
2. http://dl1.sureai.net/files/pro/enderal ... eralUpdate_[1.1.7.7][1]_EN.zip
3. http://dl1.sureai.net/files/pro/enderal ... eralUpdate_[1.1.8.5][S][1]_EN.zip
4. http://dl1.sureai.net/files/pro/enderal ... eralUpdate_[1.1.8.6][M][1]_EN.zip
Notice: you have to unpack them into your Skyrim root ../Skyrim/ unpack them in the right order. Should work then.
IT WORKED!
Thank you so much!
This game is so wizard, too!
sorry to necro this post but ever since I put in those CMD commands my steam-based servers on mutliplayer games dont work. I can't connect to any and they don't even show up.
Is this a coincidence that it happened around the same time as doing those commands or could they be related?
