74 posts • Page 2 of 4
I have tried to execute launcher on virtual machine. There is the same Windows 7 64 as on main machine. And there is no crash, just a message that Skyrim not installed.
Here is the problem signatures
Problem Event Name: CLR20r3
Problem Signature 01: enderal launcher.exe
Problem Signature 02: 1.1.0.0
Problem Signature 03: 57affa81
Problem Signature 04: mscorlib
Problem Signature 05: 4.0.30319.17929
Problem Signature 06: 4ffa57ca
Problem Signature 07: 43c1
Problem Signature 08: 1b6
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7600.2.0.0.256.1
I made a clean install. Uninstalled and reintsalled Net frame. Still launcher doesnt work.
Make sure you have steam installed.
I have not steam on other machine and i receive normal message. This is not why it crashes.
Thallanar wrote:
The launcher did not work at all on my computer. Just this error pops up, shown in the link I provided.
Since the launcher has not worked in any versions, I could not install through the launcher. It simply will not open.
I've never posted a log of anything before so if this is incomplete, please let me know. Here is the LauncherLog:
In your first post you said you installed and uninstalled many times? You are not supposed to unzip the installation file by yourself into the Skyrim directory.
Just dowload the launcher and put it your Skyrim directory. Run it. Follow these steps.
If an error apears give feedback and: Attach your LauncherLog again.
It could be that your anti virus / windows defender is blocking the execution.
Maybe try the 32bit Version. You need this version if you want to start it with Modmanager.
Hello, i have a problem with Enderal Launcher, when i want to start it, he just stop working. "Enderal Luncher stop working" what should i do ?
it's telling me that my installation didn't go to where it should have. and can you link this video?
Razien wrote:
do you have a clean install of skyrim? with no mods no files or saves in documents or tweaked inis?
enbs etc? im gonna do that first you also need the games files from the torrent prefered the things is as isaw in a video after
you open laucher you need to select the game files 7.8 gigs from torrent etc
does any got problem with clean install and firewall exeptions antivirus off and run as admin ? if yes it should be
the problem of the launcher
but as same video said you can put laucher anywhere in your drive it dont matter
I have no tried a clean install of Skyrim, yet. I'm going to try that when I have time today. Thanks for the advice.
So there is still no fix for those of us who simply cannot get any life out of the launcher at all? :/ Disabling AV, moving around the install of both Skyrim and the launcher/data file and every other thing suggested here thus far has not worked.. I'm really at wits' end..
Ok guys i think i know what the problem is. You need to have Steam installed. When I unistalled steam for a moment because i had an idea the error Enderal has stopped working appeared. When I installed steam back it worked again so there you have it :)
Run the launcher as administrator. Remove write protection in your Skyrim directory.
Please attach you LauncherLog:
C:\program files(x86)\Steam\steamapps\Skyrim\EnderalLauncher\system\log\launcher
I did a complete uninstall and reinstall of Steam, and re-downloaded and installed both the Enderal installation files and Enderal Launcher file, put the Launcher in my Skyrim directory and it still crashes when loading. I have completely run out of options, not even the moderators know how to help. It seems Enderal is impossible to play for the unlucky few who cannot get it to work.
Like i already wrote. I do not have Steam and Skyrim on other computer. And launcher do not crashes just shows a message that Skyrim not installed.
Maybe i will update the OS from 7 to 10 on the weekends. Worth to try.
do you any of you got a clean install of skyrim withough any documents inis saves or whatever?
Dude, I think most people, myself included, installed Skyrim specifically to play Enderal, so yeah, most of us do, I imagine.
I had the same problem but just now fixed it myself.
To get the launcher running, you need to execute the .exe via cmd.
> run cmd as admin
> type in: cmd /K "folderLocation\Enderal Launcher.exe"
> mine looks like this cmd /K "I:\Steam\steamapps\common\Skyrim\Enderal Launcher.exe"
That should do it, worked for me at least
Well, that actually almost did something.. there was a little jerk of the screen and that windows 'loading' icon instead of the cursor, but no luck again. Well, gawd damn.. thanks anyway dude, maybe you're onto something :)
To run the launcher make sure you have .NET Framework 4.5 installed.
If it creates a LauncherLog it would be great if you could attach it.
Otherwise ou launcher programmer has to look into this problem.
Yeah, 4.5 is installed.. where would this log be, in the same directory? If that is the case, I am afraid there is no log.. I guess that makes sense since I think the launcher actually does not ever launch.. it does not crash or anything, just never gets to the stage where it is loaded..
Aplicación: Enderal Launcher.exe
Versión de Framework: v4.0.30319
Descripción: el proceso terminó debido a una excepción no controlada.
Información de la excepción: System.NullReferenceException
Pila:
en Launcher_01.cs_Functions.workingDirectorySearcher(System.String)
en Launcher_01.cs_Functions.FormFunctionsLoad()
en Launcher_01.mainPan..ctor()
en Launcher_01.cs_Program.Main()
that's what happens when I try to open the launcher. My Skyrim is not intalled in the steam directory because the route was too long for creation kit to find the many resources I have installed. Could it be the reason? Does it only works when it's in that specific directory?
