I've experienced a similar bug, though it's not about eq. I have chosen the warrior star-sign and I somehow can't seem to remove my stance, I can only change between attack and defensive, I also have a -3 to -8 on endurance when in attack stance, without any diseases or anything. Also, the item Minor Seal of Endurance (+30 endurance) doesn't add green or base endurance in the character attributes tab, but it shows in the active effects tab as +30, how come?
really weird. It gives a fatigue bonus as well, but it just doesn't show in the window with all the other attributes (strength, agility, sneak, willpower, intelligence, luck etc)
edit: the same thing is with all rings, no rings that give +endurance seem to show in the attributes tab
In Nehrim, the usage of the word fatigue is changed to endurance, as it makes more sense. However, this can cause confusion because endurance has the potential to mean 2 different things now. Basically, if you see an item with a bonus to "endurance" either equip it and check whether the attribute or your "fatigue" increases, or just make your guess off of the amount increase. I doubt there's any item that adds 30 points to a stat, let alone a "minor" item
In my opinion the word fatigue (which describes the green bar in Oblivion) makes sense, as it works a bit different than the common endurance bar found in other games.
However, i would also use the word constitution instead of endurance for the stat, cause it is more common in this matter, but meaning the same.
If a ring adds +30 endurance, it sure means the attribute that governs the green bar(Fatigue).
Isn't this fatigue-vs.-endurance mess cleared up in 1.0.9.0?
