21 posts • Page 3 of 3
Check filesize / checksum for "EnderalInstall_EN.gz" from source / try another download source (Torrent).
Size 7.85gb (8,427,964,531 bytes)
Downloads73,272 (114 today)
MD5 Hash 082699597e64347e1aa440bc871eca2c
- OK? Next step >
Start with a new 'Clean Install'.
Consider a backup of all your configuration / save games / mod data:
- \\steamapps\common\Skyrim\ [Skyrim Install Directory]
- \\Documents\My Games\Skyrim\ [Configuration, Saves]
1. Uninstall Elder Scrolls V: Skyrim through STEAM.
- Open STEAM - goto your Library - find 'The Elder Scrolls V: Skyrim'
- Right click and select 'Delete local content'
2. Remove all old files and folders of your prior Skyrim installation before proceed-ING with the next steps.
- \\steamapps\common\Skyrim\ [Skyrim Install Directory] delete / rename the folder 'Skyrim'.
- \\Documents\My Games\Skyrim\' [Configuration, Saves] delete / rename the folder 'Skyrim'.
- If you're running low on disk space, empty your Recycle Bin'.
4. Now Install SKYRIM in STEAM.
5. Start Skyrim once and exist (so it autodetects settings) / Start Skyrim and test your default game.
6. Install Enderal. (Enderal Wiki: http://en.wiki.sureai.net/Enderal:Techn ... stallation)
7. Update Enderal with Enderal Launcher.
Edit:
--- Possible Solution #2 ---
Check "Skyrim.ini" in \Documents\My Games\Skyrim\Skyrim.ini and add / modify:
[Archive]
bInvalidateOlderFiles=1
sResourceArchiveList=Skyrim - Misc.bsa, Skyrim - Shaders.bsa, Skyrim - Textures.bsa, Skyrim - Interface.bsa, Skyrim - Animations.bsa, Skyrim - Meshes.bsa, Skyrim - Sounds.bsa
sResourceArchiveList2=Enderal - Misc.bsa, Enderal - Meshes.bsa, Enderal - Sounds.bsa, Enderal - Textures.bsa, Enderal - Textures2.bsa, Enderal - Textures3.bsa, Enderal - Textures4.bsa, Enderal - Voices.bsa
--- Possible Solution #3 ---
You didn't start the game properly through the EnderalLauncher. NO EXPECTION.
--- Possible Solution #4 ---
If you're using MO (ModOrganizer) and you don't know how to utilize MO don't install Enderal through MO.
ENDERAL / SKYRIM #Two Game Setup with Mod Organizer by Gopher: https://www.youtube.com/watch?v=Rerv5kVaTeU
