199 posts • Page 10 of 10
Re: Compatible Mods
Post by MacSuibhne »
Re: Compatible Mods
Post by kedavix »
MacSuibhne wrote:
Athletics Training?
Compatibility isn't so much of an issue since it is SKSE based. I would more or less caution you about use of it because...
From the Unstable and Outdated Mods Masterlist on Reddit:
Athletics Training - with MCM - Rating: Three (3)
This mod is considered open source by the author as per comments on the mod page and as such anyone should feel free to take it over and update it with fixes to these issues.
This mod has a unique concept but unfortunately very poor implementation which causes a lot of stress on the system. The mod implements its changes by using scripting to constantly place an item in the inventory of the player and then remove it again at a very fast pace. It is a very intensive way to do this function and takes up a lot of resources as well as opening up the risk that if the player manages to open their inventory at the exact right time and remove the item the mod may break in function. As a result, the mod is at risk of causing a significant increase in script latency by itself, and this effect is compounded when combined with other mods or when in script heavy situations in the vanilla game.
Re: Compatible Mods
Thank you for taking the time to reply.
I have always wanted to be able to jump higher and jump farther when running. Sometimes it feels like my guy is almost crippled. I've seen what looked like chest on ledges that even after an hour of trying I just couldn't get to--in Skyrim and in Enderal.
Oh well...[sigh]
Thanks again.
Re: Compatible Mods
Post by kedavix »
Oh well...[sigh]
Thanks again.
No problem. You might want to try "Better Jumping". So far, only one issuehas been reported by a user.
Re: Compatible Mods
Thanks...I saw that--it was one I looked at early on. Thought the description...with all due respect...was kind of lackadaisical--"meh," IOW. So passed on it. But I think I'll give it a try.
It will only be my fifth mod so I'm hoping it won't create problems.
Re: Compatible Mods
Post by stuemper »
"Enhanced Blood Textures" is not compatible with Enderal. It interrupts at least one scene during the mainquest.
Could someone please note that in the list, thanks!
One mod I wish could get incorporated into Enderal is "Better Dialogue Controls"
http://www.nexusmods.com/skyrim/mods/27371/?
Skyrim is terrible at recognizing where the placement of a cursor is and Enderal hasn't fixed the problem. Even when you highlight a selection with a mouse cursor, a different option will sometimes be selected. This small mod makes it so whatever option you click on is actually selected. It also helps with keyboard selection.
Re: Compatible Mods
Post by R'Q »
I started playing Enderal few days ago and of course I play with mods. I will post here any compatibility issues. It can be later added to the Compatible Mods List.
Replacement Ivy causes crashing (probably a memory issue).
I also play with following mods active:
SMIM (+ Enderal fix)
Skyrim HD
8K Pine Forest
Tamriel Reloaded - Mountains and Rocks (4K)
HD Photorealistic Ivy
Glowing Ore Veins 300
moreHUD
and I haven't encountered any issues. I will post here if anything causes problems. If I finish the game without any issues, I will consider a mod compatible.
Re: Compatible Mods
I found SMIM to cause crashes. But I don't think I have the "Enderal fix". Where did you get it?
Re: Compatible Mods
Post by R'Q »
http://www.nexusmods.com/skyrim/mods/80571/?
Re: Compatible Mods
Post by Palito »
When I played Enderal I found that having SMIM +patch broke on of the main quests.
The one were you follow the group to the ritual site.
It may have changed in the recent months.
Enderal 5 sticks riddle - more time: http://www.nexusmods.com/skyrim/mods/78041/? was really helpful.
It made it possible to complete this section.
Enderal-Lefthandrings: http://www.nexusmods.com/skyrim/mods/80810
Minimal HUD: http://www.nexusmods.com/skyrim/mods/33482/?
Helmet Toggle: http://www.nexusmods.com/skyrim/mods/22765/?
Reverb and Ambiance Overhaul - Enderal: http://www.nexusmods.com/skyrim/mods/82701/?
None of these caused problems for me.
I played a much older version of Enderal.
Re: Compatible Mods
Post by badgesareus »
Probably not. see: https://forum.sureai.net/viewtopic.php?f=209&t=12241
Re: Compatible Mods
Post by Palito »
I see.
So it really should be marked as incompatible. Even with the patch.
Re: Compatible Mods
Post by R'Q »
30.08.2017 05:15Palito wrote:
I see.
It's "partially compatible". Problem occurs only in this one point of the MQ and only then there is a need to turn it off.
I can't imagine playing Skyrim/Enderal withous SMIM or HD textures.
In fact, let me show you, how unmodded Enderal looks like.
LOL
Re: Compatible Mods
Post by Buccaneer »
I don't know if I quite agree. I had always played Tropical Skyrim with all of its different biomes and fauna and flora...and it was a drag on my system. With Enderal, it has same fauna and flora and lots of vegetations everywhere and it runs flawlessly. They obvious optimized a lot of things and if they have lower resolution objects, that's a great trade-off. To have a lush, beautiful world that runs fast is worth any compromises they made.
Re: Compatible Mods
I play Enderal unmodded so this looks normal to me. You'd have to show me a pic of the same scene with your mods for me to know what the difference was.
Re: Compatible Mods
Post by danprada »
Are you guys still updating this?
hunterborn is no longer compatible. the patch doesn't work properly (wrong items when using hunterborn functions).
and also i can't open the google sheets. it keeps loading and nothing happens.
Re: Compatible Mods
Post by Kermit 61 »
In my opinion, that makes sense only after the Add On Forgotten Stories has been released (the developers are still working on it).
Then it has to be re-tested which mods are still compatible.
Re: Compatible Mods
Post by Alzucard »
Btw. im updating the list right now.
So after the DLC we must retest and it would be great to know what things dont work anymore.
