17 posts • Page 2 of 2
I loaded earlier saves but they are also bugged. Every location, not only Ark. But it looks like Skyrim also doesnt't work. When i launch it the screen is green and the game crushes.
Re: Bugged saves
Post by urst »
hm, in this case I'd say uninstall Enderal completly,
and either reinstall Skyrim, or at last "Verify Integrity of Game Files" (or...whatever it's called in english - you know what I mean)
then start Skyrim and see if it works as it should.
then reinstall Enderal.
sucks, but other than that... :?:
(there are instructions on how to use both games more or less at the same time
if you're interested in that;
I also could type out what I did :) )
When i stopped playing enderal few months ago I uninstalled Skyrim but not enderal and now i installed Skyrim again. Maybe its something with that. Anyways i'll reinstall Skyrim maybe it will work. :)
So I uninstalled Skyrim and Enderal then installed Skyrim again and it was working. Then i installed Enderal and Skyrim started crushing again.
Re: Bugged saves
Post by stuemper »
Have you used a new installation package to install Enderal or did you use the archive version?
I used new installation package.
Re: Bugged saves
Post by stuemper »
Well, either your installation package was damaged or something went wrong during the installation process. I can't recommend anything but a reinstall. Make sure that you have the newest launcher version and run it as an admin. Also check if your firewall / anti virus / windows defender is preventing the launcher from installing. Start Enderal from the Enderal launcher and not via SKSE.
