After Yuslan and I went our seperate ways in the monastary I killed a horde of enemies, saw the vision where Yuslan killed the mercenary. After that I needed to follow an arrow where I would meet up with Yuslan again. I'm at that arrow but no cutscene is happening. I can't reload it either.
What is the quest id of ''A drop in the ocean'' so that I may progress?
It's the ONLY quest that isn't on the list that I've found. Get a load of this.
hi, welcome to the forum!
could you please attach a savegame? or better, multiple, a current one and one before entering the monastery
(or the last autosave or something like that. one with Yuslan near you would be good).
depending on your version they're found in (...\Documents\My Games\Enderal) or (...\Documents\My Games\Enderal Special Edition)
we'll need the *.ess and the *.skse files; pack both to a zip/rar/whatever archive, (the forum doesn't accept *.skse).
thank you
thank you
21.08.2021 09:26urst wrote: hi, welcome to the forum!
thank you![]()
I've added the attachments.
Thank you for the quick reply!
Saves.rar
(2.51 MiB) Downloaded 691 times
Hello Gintorias
For me the Save works if I go back to the library first, somehow you skipped a vision.
But we always test without mods, if it doesn't work for you, one of them is the cause.
Mods can cause errors, even those that are not always immediately visible.
It could also be due to the current combination and sequence.
We can't check all mods and we can't give support for them.
21.08.2021 12:05Stefanie wrote: Hello Gintorias
But after turning the mods off and on again, any time I want to perform a basic attack the game crashes now.. any tips for that? I know you don't support them but I would be okay with reinstalling them if that would make sense?
Hello Gintorias
I don't know most of the mods, but deactivating your mods individually and testing them would be a good option.
If you find one or two mods as the cause, the loading sequence could also play a role.
Otherwise, just uninstall the mod in question and leave it out!
(I wonder if it really has to be so many mods.)
You could also ask the creators if the mod was built for SkyrimSE.
If so, the creators are the ones who could give you support for it.
But you should make sure that your mods are built for Enderal-SE, otherwise bugs are more than likely.
