My respect to creators of enderal, you awesome. i have bug with ending of quest Black Light, Part I
Angel, after picking up black stone of the Apothecarii all became dark like always, then appear loading screen and game just close, so i cant play further, help me please.
Welcome to the forum
Did you use any Mods or cheats?
Papyrus log is not very helpful in this case.
Could you please upload a suitable savegame?
They're found in ...\Documents\My Games\Enderal\Saves
We'll need the *.ess and the *.skse file.
Best a manual save (no auto or quicksave).
Pack both to a zip or rar archive (the forum doesn't accept *.skse).
You can add the file as an attachment under the message window.
18.10.2019 21:14okllll89 wrote: My respect to creators of enderal, you awesome. i have bug with ending of quest Black Light, Part I
Yes i use some cheats and mods,
i use cheats to increase stamina armour and mana and kill command on too strong notpassable enemies
In my defense, I want to say that I usually play games for learning new plots, experiences, worlds, stories.
but the mechanics of the enderal do not let you know it until you start to level up the hero, leveling is a boring thing for me. sorry
and i use some mods to upgrade those experiences to HD and increasing speed of questing.
saves attached
saves attached
Saves.rar
(1.55 MiB) Downloaded 537 times
hi
the save loads fine on my end.
please let Steam verify your game files.
if that doesn't work deactivate or uninstall your mods - at least "Enhanced Blood" is probably not really compatible,
even if it's called "Enderal version". (it would lead to a crash during the mainquest)
keep the textures if you want/need to, but we'd really suggest to uninstall the esp
Hello, I already tried to check the integrity of files through Steam, it restored three files to me. After that, I also tried to disable all the mods and also lower the game settings.
I turned off the mods through Launcher, after trying to load the save that were previously made with the mods, the game gave me the corresponding error, regarding the fact that the save was done with certain mods but now they are not there.
The error also repeated. the first time a similar error It occurred to me when I was supposed to meet a calia in a tavern on a cold cliff while trying to enter this tavern. The game crashed.
I managed to get around this error with the setstage commands, I went on to the next stage and ignored the need to enter the tavern. Is it possible that this led to the appearance of this error or the error is repeated with this tavern.
Now I will try to enter this Tavern, there may be a problem inside.
then i will try to delete all game and download it again
and maybe someone will pass those bugged for me loading and give me my savegame back with passed mission =)
upd:
yes, tavern bugged, when i try to enter this tavern game is crashing
upd:
enb 2019_10_20 18_24_13_22.jpg (260.67 KiB) Viewed 8605 times
enb 2019_10_20 18_25_36_39.jpg (703.73 KiB) Viewed 8606 times
[Youtube]https://youtu.be/VZ-SKT2-BxY[/Youtube]
how this bug goes
how this bug goes
20.10.2019 17:18okllll89 wrote: Hello, I already tried to check the integrity of files through Steam, it restored three files to me.
Thats normal
20.10.2019 17:18okllll89 wrote: I turned off the mods through Launcher, after trying to load the save that were previously made with the mods, the game gave me the corresponding error, regarding the fact that the save was done with certain mods but now they are not there.
You are using 2 Mod Managers (WryeBash und Vortex). Both also for Enderal? Deactivate or delete your Mods also there (as I know Vortex creates is own profile
Disabling the mods in the launcher alone may not work.
You can try it with my hardsave after the dialogue with Calia (I was nice to her ...)
save.rar
(1.54 MiB) Downloaded 520 times
Thank you very much, now I completely uninstalled the game, through Steam I also unsubscribed from all the add-ons. Vortex I do not use for enderal, Only for Skyrim. And I downloaded all the add-ons for enderal from the Steam workshop. How the game downloads, I will check again if the problem persists I will start new game or I will use your save, thanks.
20.10.2019 18:51okllll89 wrote: And I downloaded all the add-ons for enderal from the Steam workshop.
IT WORKS! HE IS ALIVE! a full reload helps, thanks.
Now I will continue my adventures in the world of enderral, (I will be a liar, if I do not say), I have never seen any kind of great game, even as Skyrim could easily be surpassed. A masterpiece in everything, roles, voices, sounds, surroundings, lighting, characters, history, quests.
all this was exceeded by your team, wonderful work.
hello again, I found the problem, it is in the "NPC overhaul" mod. the problems that it creates are solved by the usual removal of the mod via launcher (screenshot attached). The mod replaces the standard three NPCs with more beautiful models and for some reason, a bug occurs in this tavern. By the way, the models deserve attention, maybe the creators will make them the basis of the game =)
