I'm having a problem with the saturation effect of craftable food and the vandal fury perk as the regeneration effect is more than high tier potions and is active during combat contrary to the description of the effect. As a result my character is nearly invincible in combat even with a combat mod that increases damage like wildcat combat. This is a problem since i'm playing a warrior and have selected the vandal fury perk and i'm now immortal except for fatal fall damage and traps.
Load order:
0 0 Skyrim.esm
1 1 Update.esm
2 2 Enderal - Handicraft (smithing) Expanded.esp
3 3 Missing Tempering Recipes for Enderal.esp
4 4 Wildcat - Combat of Skyrim.esp
5 5 TKDodge.esp
6 6 FNIS.esp
7 7 VioLens.esp
8 8 iHUD.esp
9 9 Enderal - Better World.esp
10 a Locational Damage.esp
11 b aMidianborn_Skyforge_Weapons.esp
12 c AMB Glass Variants Lore.esp
13 d Differently Ebony.esp
14 e AHZmoreHUD.esp
15 f AmbrosiaHalf.esp
16 10 CustomBookCurve.esp
17 11 DYNAVISION Dynamic Depth of Field.esp
18 12 CASM.esp
19 13 Enderal - Bank Safes.esp
20 14 DesyncBirdsOfPrey.esp
21 15 Equipping Overhaul.esp
22 16 DSerArcheryGameplayOverhaul.esp
23 17 DifficultArchery_50.esp
24 18 Chesko_WearableLantern.esp
25 19 Chesko_WearableLantern_EnderalPatch.esp
26 1a DynDOLOD.esp
Load order:
0 0 Skyrim.esm
1 1 Update.esm
5 5 TKDodge.esp
6 6 FNIS.esp
7 7 VioLens.esp
8 8 iHUD.esp
14 e AHZmoreHUD.esp
18 12 CASM.esp
26 1a DynDOLOD.esp
14.04.2017 17:03Rpkiller wrote: I'm having a problem with the saturation effect of craftable food and the vandal fury perk as the regeneration effect is more than high tier potions and is active during combat contrary to the description of the effect.
If not report it over here and attach your savegame as requested.
The vandal fury perk should only work during combat and it will be redone in the next patch anyways. So give feedback when the new patch is released.
