Hello, guys, for starters I wanted to congratulate you! I've been playing the english version of Enderal and I'm enjoying it much more than I ever had the original Skyrim. The story development, the dialogues and the overall climate puts Bethesda to shame and that's still, in my opinion, saying something.
Now, to basically cut to the chase - as the title says, I have a problem with the map. It seems that it's missing particular details - I would say that it mostly happens around the areas with water, like bays and rivers. For example the map doesn't even display the river along the road to Riverville. The shores look like they've been cut with scissors - bunches of pointy, sharp edges biting into the land and such. Furthermore - Ark isn't displayed at all, nor are the roads, for example. I find this problem somewhat aggravating - it certainly impairs the general enjoyment from the game.
I don't think it does have any connection with the notification I get when I'm in the main menu and about to continue the game. When I click the "Continue" button, I get the warning: "SKSE memory fix is not active on your game!" And then further instructions on what to do with it. But according to them, the lines in my SKSE.ini are okay, so I didn't do anything with it.
Please, help me with solving this issue. Cheers
The Map is normal. The LOD is just not loading that far and detailed. You can tweak your .ini's to make it load further - we recommend not to, because in our test playthroughs we experienced more crashes.
You can switch off the message by replacing the following in:
C:\program files(x86)Steam\steamapps\common\Skyrim\Data\SKSE\Plugins\crashfixplugin.ini (configuration settings)
to
or you can "solve" it by setting
to
With the second solution you need a better system than we stated in the minimal system requirements.
Code Select all
WarnSKSEMemoryPatch=1Code Select all
WarnSKSEMemoryPatch=0Code Select all
UseOSAllocators=0Code Select all
UseOSAllocators=1
