13 posts • Page 2 of 2
Re: The Launcher crashes
Post by Fenril »
Thank you for your file Hoxyd.
No, it's not working ; I get the following crash message :
Signature du problème :
Nom d’événement de problème: APPCRASH (same)
Application Name: NehrimLauncher.exe (same)
Application Version: 1.0.0.0 (instead of 1.0.8.2)
Application Timestamp: 4c0ea56e (instead of 4cb4cc4f)
Fault Module Name: mscorwks.dll (same)
Fault Module Version: 2.0.50727.4206 (same)
Fault Module Timestamp: 4bf4c6a7 (same)
Exception Code: c0000005 (same)
Exception Offset: 00076d55 (same)
Version du système: 6.0.6002.2.2.0.768.3 (same)
Identificateur de paramètres régionaux: 1036 (same)
Any ideas on how I could access the data files configuration without the launcher ?
After all : Oblivion works, Oblivion's launcher works, Nehrim starts correctly ... if only I could load these bloody files :evil:
Thanks again for your concern !
Post by Hoxyd »
A guy from russia send me an message some weeks ago. He had the same problem. But it was gone after he reinstalled his Windows (but maybe this is a bit drastic). I also searched the internet, but not much solutions to fix this problem. Maybe you can find something with this search words: Fault Module Name: mscorwks.dll
An other thing you can try is to rename your Oblivion directory to something like not Oblivion. Oblivion2, Oblivo, OblivionOld, whatever... and copy the oblivion launcher into your nehrim directory. It should work to select the datafiles then too.
Post by Fenril »
Your solution worked ! Thanks ! :o
* I copied Oblivion launcher to Nehrim's directory
* I renamed Oblivion directory into Oblivion2
* I started Oblivion launcher, checked the 3 data files.
* I started the game. It worked :
My character just fell into a pit !
Well, if I found a solution for the other problem, I will post.
Thanks again ! :o
