23 posts • Page 2 of 3
Re: 1440p?
Post by Hidden308 »
Topken wrote:
You can always set it via User-define in the settings.
I tried that as well. Still does not show up. The 1440p resolution shows up fine on normal skyrim and other games. Just does not on this but that other one like as if it is windowed mode even though I unchecked windowed mode.
Re: 1440p?
Post by Xagul »
Good Lord, 257 times in a row.
You're using an unsupported resolution. Use FlawlessWidescreen, that should fix your issue.
http://forum.sureai.net/viewtopic.php?f=208&t=10027
Re: 1440p?
Post by Hidden308 »
Well I am not using UltraWide. Just the usual 2560x1440p. 3440x1440 21:9 is Ultrawide. I am not Ultrawide. I mention 2560x1440 in my first post. :P
Re: 1440p?
Post by Hidden308 »
Anyone else knows more about this?
2K, 4K Resolution?
Post by Preslavikus »
Hello there! So when I open up the launcher it wants to run in 2194x1234 and gives no option for any other resolution. If I click the One Tweak option all it does is it lets me choose from 10 or so different resolutions the biggest being 1080p. Is there any way to go to 2k or 4k? Maybe from an ini file?
Okay.... After a few minutes of trying to remember how to manually change the resolution of skyrim I have found a solution if anyone is interested in this.
In order to get the desired resolution 2k or 4k, whatever the case all you have to do is edit your pref file in the skyrim documents directory. For anyone who doesnt know where that is, its located in (win10) C:\Users\********\Documents\My Games\Skyrim
******* = your computer's username
Once in the folder you can open the SkyrimPrefs.ini file (if win asks you how to open the program select notepad)
Under [ImageSpace] category you will find the following
bFull Screen=1 -this option is for enabling full screen as you see here
bFXAAEnabled=0 -this option is for fxaa disabled currently
iSize W=3840 -these 2 are your resolution and can be set to whatever you wish your game to run at
iSize H=2160 -not sure how this scales for wide format monitors
Re: 1440p?
Post by Hidden308 »
I guess not. :(
Re: 1440p?
Post by Deathstr0ke_DC »
This is what you're looking for. http://skyrimelder.weebly.com/ini-tweaks.html
Re: 1440p?
Post by Hidden308 »
I tried it didn't work.
Re: 1440p?
Post by mikegray »
Yeah, there's something weird going on with the launcher. I have a 2560x 1440 screen too, and my settings keep on getting knocked back to the same numbers you have: 2048x 1152. Moreover more, the launcher ALSO overwrites any changes I make to SkyrimPrefs.ini - not only resolution settings but also completely unrelated changes. Very annoying.
For a while, there seemed to be nothing I could do to get the game to start at proper resolution - no matter what, I was getting a weird window.
I was able to get it up and going properly by EXITING the Enderal launcher, THEN changing the iSize W and iSize H values (to 2560 and 1440), THEN restarting the launcher, and activating the OneTweak setting in the Launcher. My resolution numbers (greyed out) are STILL at 2048x 1152, but the game does start in borderless window mode.
However, the launcher continues to overwrite changes I make to the .ini file. So far, the only way I've found to protect other changes to SkyrimPrefs.ini is to set the file to read-only - though, of course, that pretty much shuts down the settings function on the Enderal launcher.
