Vorher funktionierte der Launcher.
Win10. Habe wie in anderen Posts beschrieben:
-launcher gelöscht und neue geladen, auch als Admin probiert - keine Änderung
-conf.sur gelöscht - keine Änderung
PS: kann man den Update zurückdrehen, dann würds ja wieder funktionieren?
Log:
> Start logging:
<14:30:34> Conf - Initialize conf file
<14:30:34> Conf - Initialize conf file [DONE]
<14:30:34> Conf - Save conf file
<14:30:34> Conf - Save conf file [DONE]
<14:30:34> Conf - Initialize Version
<14:30:34> Conf - Checking Environment
<14:30:34> Conf - Checking Environment [DONE]
<14:30:34> Func - RWP: F:\programs\games\steam\SteamApps\common\Skyrim\EnderalLauncher\system\ recursive
<14:30:34> Func - RWP: F:\programs\games\steam\SteamApps\common\Skyrim\EnderalLauncher\update\ recursive
<14:30:34> Func - RWP: F:\programs\games\steam\SteamApps\common\Skyrim\EnderalLauncher\backup\ top level
<14:30:34> Func - RWP: F:\programs\games\steam\SteamApps\common\Skyrim\ top level
<14:30:35> Main - Initialize Unpatcher
<14:30:35> Unpa - Start cleanup
<14:30:35> Main - Unpatcher [DONE]
<14:30:35> Main - Create environment
<14:30:35> Main - Create environment [DONE]
<14:30:35> Main - Initialize network
<14:30:35> Net - Connection enabled in settings
<14:30:35> Net - System is connected to network
<14:30:35> Net - Try to establish server connection thread
<14:30:35> Net - Thread STARTED
<14:30:35> Main - Initialize network [DONE]
<14:30:35> Main - Initialize intervall
<14:30:35> Net - Connect to dl3
<14:30:35> Main - Initialize intervall [DONE]
<14:30:35> Net - Server connection attempt #1
<14:30:35> Main - Initialize PanBase [DONE]
<14:30:35> Main - Initialize CPanel
<14:30:35> Cp - Cp Initialisation
<14:30:35> Cp - No connection to server established yet, try again in 5 seconds...
<14:30:35> Main - Initialize CPanel [DONE]
<14:30:35> Cp - Check Cp file
<14:30:35> Net - Connection default port: True
<14:30:35> Cp - Read old Cp file
<14:30:35> Net - Connection proxy bypassed: True
<14:30:35> Conf - Hardware Scan:
<14:30:35> Cp - Start Cp pic checker
<14:30:35> Conf - GPU: NVIDIA GeForce GTX 1070, Memory: 4 GB
<14:30:35> Cp - All pics found
<14:30:35> Conf - DISC: 5406965 MB
<14:30:35> Net - Connection OK
<14:30:35> Net - HttpWeb: Start listing available versions:
<14:30:35> Net - HttpWeb: 1.0.0.2 S 1
<14:30:35> Net - HttpWeb: 1.0.0.3 M 1
<14:30:35> Net - HttpWeb: 1.0.0.4 S 1
<14:30:35> Net - HttpWeb: 1.0.0.5 M 1
<14:30:35> Net - HttpWeb: 1.0.0.6 S 1
<14:30:35> Net - HttpWeb: 1.0.0.7 M 1
<14:30:35> Net - HttpWeb: 1.0.0.8 S 1
<14:30:35> Net - HttpWeb: 1.0.0.9 M 1
<14:30:35> Net - HttpWeb: 1.0.1.3 S 1
<14:30:35> Net - HttpWeb: 1.0.1.4 M 1
<14:30:35> Net - HttpWeb: 1.0.1.7 S 1
<14:30:35> Net - HttpWeb: 1.0.1.8 S 1
<14:30:35> Net - HttpWeb: 1.0.1.9 M 1
<14:30:35> Net - HttpWeb: 1.0.2.1 S 1
<14:30:35> Net - HttpWeb: End
<14:30:40> Cp - Retry thread started attempt #1
<14:30:40> Cp - Try to compare server with local file
<14:30:40> Cp - Connection port: 80
<14:30:40> Cp - Connection default port: True
<14:30:40> Cp - Connection proxy bypassed: True
<14:30:40> Cp - Connection OK
<14:30:40> Cp - 04.07.2016 00:09:01 16.07.2016 11:05:16
<14:30:40> Cp - Up-to-date
<14:30:40> Cp - Check Cp file
<14:30:40> Cp - Read old Cp file
<14:30:40> Cp - Start Cp pic checker
<14:30:40> Cp - All pics found
Log:
> Start logging:
Probier noch mal PC neu starten.
Werter Herr Hoxyd, vielen Dank. Ein altes Sprichwort sagt ja "Reboot tut gut", da hätte ich auch dran denken sollen.
Und so mache ich mich mal wieder auf den Weg nach Ark.
