Hi guys,
first of all I want to thank you for Nehrim, I found it really immersive as a RPG should be.
I create this thread because I did a real stupid thing: I decide to test this total mod and because I was't serious (I have never found a total mod real interesting) I didn't save my game using normal saves but I used only quicksaves and autosaves. I did it also because I know that Oblivion backup quick/autosaves and so I thought "who cares if the quicksave doesn't load? I can load the backup...". Now I have a corrupted quick and autosave and also the two backups are corrupted.
The problem occurred when I have exchanged my player for Kim so that she can be free. My player wakened in the jail, Kim saved me and we tried to escape. I killed all the guards inside the building and try to exit. When I exit I decide to reload to check if inside the building there is my equipment and the crash loop started. I replace the quicksave and the autosave with their backups but nothing is changed.
Now the crash appens if I try to load the quicksave or the autosave but for the first one sometime the game load and crash after the message about the quest
"The path Kim used to come in is too sleep to climb up. Unfortunately, the only door[...]"
So I managed to open the console when those luckly loads finished and save the game but it is clearly corrupted as it can be seen by the location of the save game. I attached a zip containing the two autosaves, the backup of the quicksave (I lost the last quicksave) and test2 that is the save done using the console before the crash. Maybe they can be useful to debug the bug.
Thanks for your time,
rief
p.s. maybe somebody can send me a saved game in the same part of that mission or before (even hours before, it is better than restart the game
rief
riefsaves.zip
(1.58 MiB) Downloaded 288 times
