2 posts • Page 1 of 1
Nehrim is randomly crashing and freezing a lot and it seems to get worse then better at times too. It is very annoying as the last three times I just tried I could barely travel for 5min without it freezing or minimizing to the desktop.
I have nehrim installed to C:/Games/Nehrim
My current mods are Nehrim Engrish text
NIE
Nehrim Kim Upgrade
Nehrim donkey flute (got a horse now so dont really need this anymore)
QTP3 full
My graphical settings are all maxed out but my CCC settings are a customized to my liking, which is a above balanced but before max quality. On oblivion I play max quality and settings (ccc settings may be lowered due to quality depending on the amount and types of mods i have installed)
Here are some of my system specs:
W7 Ultimate 64
AMD Quad Core 3.4
4gb RAM
Had the cpu overclocked a little when I paly but took it off to see if itll reduce crashing. I have it normally at stock and the computer settings as max energy saving because I leave my computer on a lot.
I also have everything in the optimizing part of the settings checked as well
If there is anything else you need to know, let me know. Hopefully you can help.
I may test, what happens when I lower the graphical settings in CCC (Catalyst Control Center for ati video cards).
fixed, i uninstalled, cleaned and reinstalled. works fine now
at least not as much freezing still has its problems but thats oblivion for you lol
