Hi
Thank you Nehrim Team for this beautiful work of art
Request?
The NehrimLauncher.exe is quite remarkable. It is very useful and advanced.
The installation process of NehrimInstall_1.0.7.5_EN.exe was very concise and competent.
How ever...
Yea I'm one of those people I suppose
I would greatly appreciate the NehrimLauncher.exe respect the INI setting bUseMyGamesDirectory=0. I am setting up my game to place Oblivion.ini in "F:\Program Files\SureAI\Oblivion". I had the installation in "F:\Program Files\SureAI\Nehrim" but Wrye bash would not respect the folder name Nehrim in relation to its own current procedure for locating oblivion,ini and Pugins.txt.
If the oblivion.ini setting
[General]
then Oblivion.exe will look in the same folder it resides in for the \saves\ folder, the oblivion.ini, the pugins.txt and dlclist.txt. I posted at
DLCList.txt and Plugins.txt in App folder regarding Bash support for the settings in the game folder and now I am asking for NehrimLauncher.exe support here.
Thank you again Nehrim Team for this beautiful work of art. I am in awe of the devotion to detail and intelligent design I am encountering in Nehrim.
Request?
How ever...
[General]
Wow, that's great. Thanks sativarg, never heard of that option, but i will check it out.
It works. I will upload a version of the launcher tomorrow.
Ok, i uploaded the file. You can find your recommended option inside the extra tab at the settings menu.
HI
Thanks you for your reply.
I have been on a manic binge, a miserable lifestyle and even worse excuse. this reply is late as I have been gradually putting pieces of the wreckage back in some order. I had not gotten any notices about this post. I will have to review my settings here.
Here it is
That's better
I am glad that my suggestion was useful. That is what I do I suppose when I am not spewing alcoholic madness... I try to be of some small use.
Here it is
Code Select all
Notify me upon replies by default: X:yes I am glad that my suggestion was useful. That is what I do I suppose when I am not spewing alcoholic madness... I try to be of some small use.
The new feature is working and settings are being applied to the INI file in my game folder.
The launcher did not like my INI file and replaced it. As a result I lost some faunt settings I had adjusted to better accommodate DarkUId DarN 16 This replacement may have been because of the initial lack of any INI in the default location.
Nehrim - DarN UI Dialog Patch
I had a backup of my ini so no problem. I make lots of backups.
Code Select all
[Fonts]
sfontfile_1=Data\Fonts\DarN_Morris_Roman_28.fnt
sfontfile_2=Data\Fonts\DarN_Kingthings_Petrock_14.fnt
sfontfile_3=Data\Fonts\DarN_Kingthings_Petrock_16.fnt
sfontfile_4=Data\Fonts\DarN_Oblivion_28.fnt
SFontFile_5=Data\Fonts\Handwritten.fntCode Select all
[Fonts]
sfontfile_1=Data\Fonts\Kingthings_Petrock_22.fnt
sfontfile_2=Data\Fonts\Kingthings_Petrock_22.fnt
sfontfile_3=Data\Fonts\DarN_LG_Kingthings_Petrock_18.fnt
