Just wondering whether the option "Dual CPU using" should be enabled or disabled with a quad-core CPU, and what the effect is. Obviously, it's not a dual core CPU, but it's better if the game uses two CPU cores than just one. Or, will the game be able to use four or more cores if you disable this option but leave "Multithreading" enabled?
Bump.
Enabled.
